Archive 2012 · San Francisco in Black and White
gdanmitchell
p.1 #1 · p.1 #1 · San Francisco in Black and White
Partly as a result of a interesting discussion in the landscape forum and partly because I do a lot of this sort of photography, I'm going to make a point of contributing more work here and of trying to participate in more of the dialog here.
Here are a few of my older San Francisco black and white photographs. (The first one is old enough that it uses the old black borders that I stopped using a few years back!)
I do most of this work handheld and while walking around the city, though a couple of the images in this set were shot "landscape style" from the tripod.
Thanks for looking.
http://gdanmitchell.com/gallery/d/297-3/GGBridgeTowerCloseBW2007_11_23.jpg
1. This is, obviously, a night photograph. It was made from the near the north end of the Golden Gate bridge with a long lens. (And, yes, this version was toned a bit - probably need to update and re-think that choice. ;-)
http://gdanmitchell.com/gallery/d/3787-2/GGBridgeNorthTowerSFSkylineBW20091218.jpg
2. This is an iconic view known to many photographers in the Bay Area, and there is a spot that is about 4 feet wide and perhaps 30 feet long from which you can see the Transamerica Pyramid juxtaposed inside the upper portion of the GG Bridge.
http://gdanmitchell.com/gallery/d/321-3/SFBayMorningShipsMOD2006071.jpg
3. This is a scene that frequently photograph on early morning walks along the Embarcadero.
http://gdanmitchell.com/gallery/d/3752-2/ConvergingBuildingsCloudsSFBW20090916.jpg
4. This is one of many spontaneous architectural shots I've made while walking through downtown SF.
Apr 26, 2012 at 10:26 PM
Peter Figen
p.1 #2 · p.1 #2 · San Francisco in Black and White
Dan - Very nice. You images are classing up the joint.
Apr 27, 2012 at 02:42 AM
charlieboy
p.1 #3 · p.1 #3 · San Francisco in Black and White
I really like the last one...Can I ask what lens body combo?
Apr 27, 2012 at 04:39 AM
SKumar25
p.1 #4 · p.1 #4 · San Francisco in Black and White
Wow, well done Dan!! Did you use super teles for numbers 1 AND 2?
Apr 27, 2012 at 04:47 AM
gdanmitchell
p.1 #5 · p.1 #5 · San Francisco in Black and White
Thanks for your comments, folks. I would have to look up the EXIF or the original images to tell you for sure which lenses I used in a couple of cases. But here is what I remember.
1. I'm almost certain that I used the (Canon) 70-200mm f/4 non-IS for this one.
2. I'm positive that I shot this with the 100-400mm zoom.
3. I'm almost sure that the third was shot with the 70-200mm f/4 again.*
4. This was most likely shot with the 24-105mm f/4, but see the note below.*
* I vacillate between using a couple of zooms for my frequent on-foot San Francisco photography (which produced the last two examples) and using one or more primes. So there is a possibility that one of the last two was shot with a prime - possibly the 50mm f/1.4 in the let one.
Apr 27, 2012 at 03:26 PM
ldrussell
p.1 #6 · p.1 #6 · San Francisco in Black and White
I really appreciate your "eye" for compostion. The simplicity of the images are wonderful. All I can say is WOW!
Apr 27, 2012 at 03:50 PM
