Archive 2012 · Nikon 16-35 and 50 or 24-70
Kell
p.1 #1 · Nikon 16-35 and 50 or 24-70
Hi, long time listener, first time caller. Got into photography a year ago and a friend turned me on to this great site! Hoping for some opinions/advice on a decision. I shoot a wide variety of scenery, people and action. I have a D700, 16-35 VR, 50 1.8 and 70-200 VRII. I hate changing lenses. Was considering selling the 16-35 and 50 and getting a 24-70. Would just use one or the other for different situations and have 24-200 covered. Here's my pros and cons and would appreciate you adding any to help me decide. Thanks.
Pros:
Only have two high quality lenses.
Less switching. Less dust exposure.
Wide angle to tele range.
Cons:
Cost, would probably have to spend close to a grand to make the switch.
Weight, no more lightweights. Might deter me from using as much but I would still have the X100.
Give up VR and low light option.
Give up the 16-24 range.
Couple other factors I'm unsure of. I have to dial the 16-35 up to around 20 to get rid of distortion. Is the situation the same with the 24-70? If I had to do the same I would effectively be adding 'Give up wide angle' to the list of cons and think that would be a show stopper alone.
I have an SB600 I rarely use. Would I need to be using that for indoor photos on the 24-70? Suppose for what I could get for the 50 I could just keep it. I'm not great with it though. Blur is a problem. Need to improve my hand holding technique.
Thanks, appreciate your time!
Apr 10, 2012 at 02:03 PM
ChrisDM
p.1 #2 · Nikon 16-35 and 50 or 24-70
How often do you shoot your 16-35 below 24mm? I think your answer is in that answer.
Apr 10, 2012 at 02:42 PM
Kell
p.1 #3 · Nikon 16-35 and 50 or 24-70
Well, it's my newest equipment so haven't used it too much, but did like the 20mm view and photos from the coast and Gorge. Suppose another option is to get a D7000 for the cost of the upgrade and just leave the 70-200 parked on it making it more like 100-300. Thanks.
Apr 10, 2012 at 02:49 PM
VinnieJ
p.1 #4 · Nikon 16-35 and 50 or 24-70
Performance wise you can't go wrong either way unless you want to shoot wider than 24. I just don't think it would be worth $1K to make the switch.
I have the 16-35 and a 50 as well. I use to have the 24-70, if I still needed the convenience of the mid-range zoom I would get it again.
Apr 10, 2012 at 02:55 PM
Kell
p.1 #5 · Nikon 16-35 and 50 or 24-70
Thanks. Certainly don't need every millimeter covered and my current setup is nice. Seemed more covenient as you said as well as the 24-70 sounding as amazing as the 70-200.
Apr 10, 2012 at 02:59 PM
Micah25
p.1 #6 · Nikon 16-35 and 50 or 24-70
Lost my 16-35 on a job, kid of glad I did. Picked up the 24-70 2.8 and it's an amazing piece of glass. I was not happy with distortion on 16-35. I was using it for interiors (better to use the 24 PC-E for that type of work). So go for the 24-70 2.8 you won't be sorry. As for the low light, you have a D700, jack up your iso, don't be afraid.
--Micah
Apr 10, 2012 at 03:14 PM
Kell
p.1 #7 · Nikon 16-35 and 50 or 24-70
Must admit, the thought of having just two of among the finest lenses Nikon makes, that will capture everything I like to photo is tempting.
BTW, if I do this what's a reasonable used price for the 16-35 (about $1,200 new) and 50 ($130 new) which are like new, perfect with very little use? And is FM B&S as good a place as any to sell them?
Thanks.
Apr 10, 2012 at 03:26 PM
Smiert Spionam
p.1 #8 · Nikon 16-35 and 50 or 24-70
I wouldn't do it. I find f/2.8 midrange zooms to be cumbersome and dull, except for events and journalism. I've rented the 24-70 for a couple of paid gigs shooting events, and it's invaluable for that -- but I find it a fairly poor choice much of the rest of the time. The 16-35 is actually better at 24mm, and obviously covers the wide end better.
Other people feel differently about the matter, though.
Apr 10, 2012 at 03:55 PM
Kell
p.1 #9 · Nikon 16-35 and 50 or 24-70
Thanks, the one thing I was concerned about was if I had to bump up to 30mm on the 24-70 for scenic/landscape which would defeat the benefit of FF and WA.
Apr 10, 2012 at 03:59 PM
Uzay
p.1 #10 · Nikon 16-35 and 50 or 24-70
How is the distortion in 24-70, i hate distortion, sometimes i can correct it but i don't want to deal with distortion
Apr 10, 2012 at 04:02 PM
Kell
p.1 #11 · Nikon 16-35 and 50 or 24-70
The million dollar question for me. I don't use any post processing software, just try and take as good of jpeg's as possible for simply enjoying and printing when I get any worthwhile. All the reports are correct about the 16-35 having stong distortion at 16mm, but significantly improving at 20mm. If the 24-70 at 24 is in a similar situation, then I've made my decision to stay put.
Apr 10, 2012 at 04:09 PM
Smiert Spionam
p.1 #12 · Nikon 16-35 and 50 or 24-70
The 24-70 does not have as much distortion at 24mm as the 16-35 has at 16 -- but it does have more than the 16-35 at 24mm.
Honestly, if you're just getting started and only shooting jpegs, it's probably not a big deal one way or another, since you're not likely pushing either lens to its limits. You might consider other options -- such as a slower (but lighter and more easily carried) 24-xx lens for casual use that could be a supplement to, rather than replacement of, your 16-35. The 24-120/4 VR is highly regarded, and might serve you well. There are also some decent third party mid-range zooms. If you use one of these for a while and decide you like it, you can let the 16-35 go with minimal hassle.
The 24-120 is also probably a better choice than either the 16-35 or the 24-70 if you're looking to head out with just a single lens mounted on your camera. It covers a lot of territory pretty well.
The 24-70 is a great tool, without a doubt -- but it's big, heavy, and expensive. Those are not limiting factors for a lens that gets regular professional use, but it sure isn't a lens I want to carry around casually.
Regardless, try to spend some time shooting with just the 50mm -- you'll probably find your learning curve accelerating more quickly working with its constraints (and excellent image quality).
Apr 10, 2012 at 04:24 PM
Kell
p.1 #13 · Nikon 16-35 and 50 or 24-70
Thanks. My main goal was to just have 2 lenses of the best quality money can buy that will cover all of my photo interests. That 24-70 has been hard to get out of my head after reading the glowing reviews. If it's truly on par with the 70-200, man...pure heaven :-)
Apr 10, 2012 at 04:35 PM
Justin Berman
p.1 #14 · Nikon 16-35 and 50 or 24-70
What I want to know is how bad is the distortion really. The lens certainly seems to have more than say a 14-24, but accepts filters (which the 14-24 does not). I have seen a lot of photographers work (on 500px for example) who are doing excellent landscape with with 16-35. Hell, one of my personal favorites (Joe Rossbach) uses the 16-35.
I genuinely think you may be obsessing unless you need to use the lens for close up landscapes *or* you have a problem with it others don't.
Apr 10, 2012 at 04:43 PM
Smiert Spionam
p.1 #15 · Nikon 16-35 and 50 or 24-70
I've owned the 16-35 since it came out, and I have very rarely cared about distortion corrections -- all wider than 18mm, and the automatic corrections in the Lightroom profile handled it just fine. For me, it's a non-issue.
It's very easy to chase a platonic ideal of a lens in a way that doesn't really exist. Every lens has strengths and weaknesses, and I suspect that the 24-70 won't really satisfy Kell's search for the ideal lens lineup, either. No lens can do that -- and if you're not even using the tools available to maximize what you can get out of the lenses you have (shooting RAW, editing as necessary), chances are this is a theoretical problem, and not a practical one.
I say this as someone with intimate personal experience of this condition.
Apr 10, 2012 at 05:50 PM
GroovyGeek
p.1 #16 · Nikon 16-35 and 50 or 24-70
My take:
Pros:
Only have two high quality lenses - why is two lenses a pro? If you only have a hammer everything looks like a nail
Less switching. Less dust exposure - complete non-issue with dust shakeoff. My last camera was a D90. Did not have to clean the sensor once in the 3+ years I owned it.
Wide angle to tele range - depending on your perspective, 24mm is not terribly wide.
Cons:
Cost, would probably have to spend close to a grand to make the switch - small price to pay if this is what you need and use (assuming that you can afford it).
Weight, no more lightweights - Might deter me from using as much but I would still have the X100. To me this is and ergonomics are THE #1 and #2 issues. I have both a 70-200 and 70-300 and rarely use the former, despite the fact that every time I pick it up I love the character of the images. Heck, I considered switching to Canon solely for the 5D2 + 17-40/4 + 70-200/4 combo. About 3 lbs lighter than anything of comparable image quality you can get on Nikon.
Give up VR and low light option - This is what tripods are for, depending on your subject matter.
Give up the 16-24 range - That would be a complete showstopper for me. I don't care about the middle range.
Only you can answer which one is more important for you. I am working on two kits:
Relatively light-weight hiking: D800 + 20/2.8 + 50/1.8 + 85/1.8 + 180/2.8 (or 16-35/4 instead of 20/2.8)
<5 mile roundtrip: D800 + 16-35/4 + 50/1.8 + 70-200/2.8-II
I also have a 24-85/3.5-4.5 lying around the house that I will probably rarely use. It is light enough and cheap enough that I am OK tying up some money in it even if I practically never use it.
Now if my dealer actually gets around to shipping me the D800 I ordered at 12:10am on the release day I would be set. I am told "before May" but given the fact that nobody seems to be shipping anything I am not holding my breath.
Apr 10, 2012 at 11:22 PM
Kell
p.1 #17 · Nikon 16-35 and 50 or 24-70
Thanks everyone, for the much needed perspcetive. I avoided impulsiveness as a result. I'll just stay put and learn to to get the most out of what I have. Great forum!
Apr 11, 2012 at 09:05 AM
