Archive 2012 · Contax 645 80mm equivalent lenght for 35 mm? 50mm?
pompo
p.1 #1 · p.1 #1 · Contax 645 80mm equivalent lenght for 35 mm? 50mm?
Does a 80mm contax 645 lens compare to dslr to about 50mm? Or shorter?
What's the formula to get this correct?
Thanks
Apr 04, 2012 at 09:27 PM
mpmendenhall
p.1 #2 · p.1 #2 · Contax 645 80mm equivalent lenght for 35 mm? 50mm?
A 645 frame is 6cm wide and 4.5cm high. "Full frame" 35mm format is 36mm wide, 24mm high. The ratio between these gives you the appropriate scale factor: 80mm * (36mm/60mm) = 48mm equivalent horizontal field of view.
Apr 04, 2012 at 09:31 PM
Mescalamba
p.1 #3 · p.1 #3 · Contax 645 80mm equivalent lenght for 35 mm? 50mm?
Its 50mm, but thats just FOV. In theory it "should" be same, but look is different, cause theres magnification and size of sensor/lens.
Only way to get something similar would be 80mm on FF and stitching few photos together (eg. creating bigger sensor). Although even that wont be same, just closer than 50mm on FF.
Apr 04, 2012 at 09:57 PM
pompo
p.1 #4 · p.1 #4 · Contax 645 80mm equivalent lenght for 35 mm? 50mm?
thanks everyone
Apr 04, 2012 at 11:03 PM
