Archive 2012 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
ilegales
p.1 #1 · p.1 #1 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
Hi
i have just upgraded my 5d mk 1 to a mk3
and my old External sandisk card reader now is a bit slow - reads 3.5mb per second
as i have the 5d mk3 files which are double the resolution of the mk1
i would like to get a better card reader for my PC
i have usb 3 on my machine and i have always used sandisk cards and external card readers
would like to find out some recommendations please
thanks
Mar 31, 2012 at 03:02 PM
johnip
p.1 #2 · p.1 #2 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
I use the Lexar Professional USB 3.0 dual slot reader and I think a lot of other folks here do too. It does CF and SD cards. Not terribly cheap, but it is pretty fast.
http://www.bhphotovideo.com/bnh/controller/home?O=productlist&sku=845797&is=REG&LEPCRU3.0=&A=details&Q=
Mar 31, 2012 at 05:54 PM
sjms
p.1 #3 · p.1 #3 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
there's the answer
Mar 31, 2012 at 10:28 PM
ilegales
p.1 #4 · p.1 #4 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
thanks for that advice
the old sandisk all in one is really showing its age - especially now that i will be using 16 gb / 32gb cards with the 5D mk3
Apr 01, 2012 at 08:30 AM
EB-1
p.1 #5 · p.1 #5 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
Yeah, that is the one. I remove the outer part to eliminate the popup annoyance and make it more compact for travel.
Apr 01, 2012 at 08:40 AM
ilegales
p.1 #6 · p.1 #6 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
and approx how long is the cable that goes from the usb 3 to the lexar card reader ?
as my usb 3 socket is at the back of my desktop so i may need an extension cord
Apr 01, 2012 at 10:12 AM
sjms
p.1 #7 · p.1 #7 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
how long would you like it to be? it has A and B type connectors at the ends so you can use different cables. i have 1ft cables and 3ft ones. the 1ft ones come from my external USB3 drives.
Apr 01, 2012 at 11:07 AM
ilegales
p.1 #8 · p.1 #8 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
i was meaning what cable does it come supplied with (its length )
My old sandisk came with a 20cm cable supplied when it was bought
Apr 01, 2012 at 11:53 AM
sjms
p.1 #9 · p.1 #9 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
i do believe it was a 3ft (~1mtr). i've had it for awhile and have a few cables too
Apr 01, 2012 at 12:56 PM
ilegales
p.1 #10 · p.1 #10 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
3ft - ! mtr
thats pretty good -
can anyone else confirm the length of the supplied cable
ready to order
Apr 01, 2012 at 01:00 PM
Ernie Aubert
p.1 #11 · p.1 #11 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
The (only) cable that came with mine is a bit longer than 40 inches.
Apr 01, 2012 at 01:50 PM
ilegales
p.1 #12 · p.1 #12 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
thanks Ernie for that confirmation
as i dont live too close to the shop - i usually order it by post
thanks all
Apr 01, 2012 at 02:13 PM
adamfilip
p.1 #13 · p.1 #13 · Recommend a Good Fast Card Reader - for cam 5d mk3 files
Dont get the Lexar Pro USB SD and CF reader.. its junk
mine broke.. Wasted $70
Yes I hold grudges
Apr 05, 2012 at 02:46 AM
