Archive 2012 · Camera Cleaning
Creativesifu
p.1 #1 · Camera Cleaning
What is a reasonable Cost and expectation? When I shoot pictures on Solid sky or white backgrounds I see spots in the pictures.
Will a $40 cleaning at the camera shop fix this? Or are they just doing the sensor cleaning that the camera already says it is doing?
Mar 19, 2012 at 02:05 PM
WiPhotoguy
p.1 #2 · Camera Cleaning
Sounds like you need a sensor cleaning. A way to verify that is to shoot a even blue sky at f16 and you should see spots. Then shoot it at 2.8 and generally you won't see many.
The in camera sensor cleaning isn't all that effective.
Mar 19, 2012 at 06:04 PM
thedruid
p.1 #3 · Camera Cleaning
Buy a Sensor Swab with the Eclipse fluid already on it and clean it yourself, it's a lot cheaper and you can do it whenever you want. When I had a 5D I had to clean that puppy once a week.
Mar 19, 2012 at 07:25 PM
rhyder
p.1 #4 · Camera Cleaning
Creativesifu wrote:
.......... that the camera already says it is doing?
What?? Your camera talks to you??
Mar 22, 2012 at 02:27 PM
alohadave
p.1 #5 · Camera Cleaning
$30-60 is fairly typical to have a camera store clean a sensor. You can do it yourself for free once you have the tools. Google clean sensor and your camera model.
Mar 22, 2012 at 04:18 PM
dehrk
p.1 #6 · Camera Cleaning
You might want to try a rocket blower first. Solved my spots pretty handily.
Mar 23, 2012 at 02:27 PM
henryp
p.1 #7 · Camera Cleaning
Camera cleaning:
http://bhpho.to/GVKDik
Henry Posner
henryp@bhphoto.com
B&H Photo-Video
Mar 27, 2012 at 08:57 PM
nugeny
p.1 #8 · Camera Cleaning
For years I have been using a rocket blower and a small vacuum held at a small distance(depending on the power of your vacuum). It is free and works like charm.
Apr 08, 2012 at 07:35 PM
Kory Lidstrom
p.1 #9 · Camera Cleaning
I do most cleanings myself, but, sometimes after shooting in places like dunes, etc, the sensor can get dirty enough that it's time to have a pro do it. Here in Minneapolis, we have a camera shop that will clean your sensor for a flat $50 no matter how dirty it is or how much time it actually takes them to get it clean. It's well worth it on the rare occasions it's needed.
Apr 22, 2012 at 08:00 PM
DubiousDrewski
p.1 #10 · Camera Cleaning
The $42 fee at my store (Vistek) covers a sensor AND mirror/focus screen clean. And yes, it's a much more thorough cleaning than what the built-in sensor vibration will achieve.
Apr 24, 2012 at 09:53 PM
BriMcD
p.1 #11 · Camera Cleaning
Visible Dust sensor loupe and sensor swabs. look it up on you tube. It's not that hard to do.
Jun 09, 2012 at 06:08 PM
BluesWest
p.1 #12 · Camera Cleaning
On the contrary, there have been several instances where I've had spots on my 7D sensor and running the in-camera sensor cleaning mechanism a few times in a row has solved the problem. When that hasn't worked, a quick cleaning with a rocket blower, as suggested above, has done the job
I haven't had to perform a wet cleaning at all in three years of owning the camera, even though I sometimes remove and/or install an extender while in the field.
John
Jun 10, 2012 at 05:37 PM
Micky Bill
p.1 #13 · Camera Cleaning
To be honest it's not that hard. Taking your camera to the store to have a "pro" do it...the pro being the clerk who isn't doing anything for the next 15 minutes is like taking your car to the car dealer to check the air in your tires.
Jun 10, 2012 at 06:44 PM
Bob Kane
p.1 #14 · Camera Cleaning
This is a Pro forum?
Jul 26, 2012 at 07:29 PM
