Archive 2012 · Will CS3 with Lion OSX 10.68
RichardRickard
p.1 #1 · Will CS3 with Lion OSX 10.68
I would like to up grade to Lightroom 4. I would have to install OSX Lion which is I think 10.68 which I would need to run LR4.
Does anyone know if Photoshop CS3 will work with OSX?
Thanks
Rick
Mar 08, 2012 at 07:30 PM
tomrock
p.1 #2 · Will CS3 with Lion OSX 10.68
I don't have an answer for you but Lion is actually 10.7. 10.6 was Snow Leopard.
Mar 08, 2012 at 09:15 PM
Brit-007
p.1 #3 · Will CS3 with Lion OSX 10.68
CS3 is 32 bit and will not work with Lion which has removed the ability to run 32 bit apps. CS5 is the first version to run 6b bit on a Mac.
Mar 08, 2012 at 09:35 PM
dcains
p.1 #4 · Will CS3 with Lion OSX 10.68
Lion runs 32-bit apps just fine. What it lacks is the Rosetta utility, which allowed running pre-Intel legacy apps, such as Quicken, for example. CS3 should run without issues, as I can run CS5 under Lion in 32-bit mode if I choose.
Mar 08, 2012 at 09:47 PM
Mike Ganz
p.1 #5 · Will CS3 with Lion OSX 10.68
I'm running Lion 10.7.3 and using Photoshop CS3...no problems whatsoever.
Mar 13, 2012 at 07:22 PM
