Archive 2012 · Re: FIXED - LR4 Did Not import my LR3 collections
mhayes5254
p.1 #1 · Re: FIXED - LR4 Did Not import my LR3 collections
Anyone see this. I only have the pre-defined smart collections. Everything else seems OK such as Web templates, user defined print templates, etc
Mar 08, 2012 at 04:09 AM
Jefferson
p.1 #2 · Re: FIXED - LR4 Did Not import my LR3 collections
Did you tell it where to look?
Reading some other posts, you may want to wait
Jefferson
Mar 08, 2012 at 04:13 AM
mhayes5254
p.1 #3 · Re: FIXED - LR4 Did Not import my LR3 collections
No. When I upgraded it auto selected my main catalog, I set the destination for the upgrade (not the default) and it did the upgrade. I do not see a separate section for collections.
Mar 08, 2012 at 04:23 AM
mhayes5254
p.1 #4 · Re: FIXED - LR4 Did Not import my LR3 collections
Re- converted my LR3 catalog an it is OK now. Sorry but I have no idea what the original problem was.
Edited on Mar 08, 2012 at 04:52 AM · View previous versions
Jefferson
p.1 #5 · Re: FIXED - LR4 Did Not import my LR3 collections
http://forums.adobe.com/message/4249645?tstart=0
See if this is your problem
mhayes5254
p.1 #6 · Re: FIXED - LR4 Did Not import my LR3 collections
I went back and manually opened my main LR3 catalog in LR4 to trigger the conversion again and re-saved it. In the original conversion it auto selected the catalog and the image count is slightly different (~32500 vs 32300). Apparently it was not the correct one before. However it still should have had plenty of collections.
Thanks for looking into it.
Mar 08, 2012 at 04:59 AM
Alan321
p.1 #7 · Re: FIXED - LR4 Did Not import my LR3 collections
Don't you just love intermittent problems They undermine your confidence in both the program and yourself because they cannot be reliably repeated when you want to.
- Alan
Mar 14, 2012 at 04:22 AM
