       2       3       4       5       end
Archive 2012 · Samyang 24mm tilt-shift lens - now announced
Romain
p.1 #1 · Samyang 24mm tilt-shift lens - now announced
Samyang announced on Facebook that they will "for sure" release a 24mm tilt shift lens mid 2012. (see comment under the recent post of Bigelow Photo)
AFAIK, this would be the first affordable alternative to canon/nikon native TS lenses... much cheaper that schneider for example.
[UPDATE] The lens has been released
here is the press release:
http://www.dpreview.com/news/2012/09/07/samyang-24mm-f3-5-tilt-shift-lens
Samyang Optics is about to release a new lens with the perspective control function — Samyang T-S 24mm 1:3.5 ED AS UMC. The official product presentation will take place on September 18th 2012, during international photographic Photokina fairs held in Cologne.
New Samyang T-S 24mm 1:3.5 ED AS UMC is a wide-angle, full-frame lens fitted with the perspective control and tilt-shift functions. Its unique optical and mechanical construction makes it an ideal tool for architecture and landscape photography. The product will be also extremely useful when convergence of the lines in the frame is required. Owing to the mechanism of optical axis tilt, focus depth operation brings utterly new quality and possibilities, enabling photographers to shape the image according to their individual needs, both on digital and nalog carriers.
Optical design of Samyang T-S 24mm 1:3.5 ED AS UMC comprises of sixteen lenses arranged in eleven groups, including two aspherical lens and two lens made of ED glass with low dispersion factor. Thanks to this solution, the lens perfectly reproduces detailed elements and gives splendid image plasticity, also with the T-S function on. Each optical component of the product was covered with multi-layered, anti-reflective UMC coatings, which provide great light transmission factor, high contrasts and render only natural colors of the photographed scene. With sophisticated optics and developed T-S function, Samyang T-S 24mm 1:3.5 ED AS UMC is currently the most advanced lens produced by Samyang Optics and may compete with similar lenses of other brands.
Tilt-Shift function
Tilt-Shift function in Samyang T-S 24mm 1:3.5 ED AS UMC allows for smooth and individual adjustment of the focus plane angle by +/-8.5 and enables parallel shift of the optical axis by +/-12 millimeters. To make Tilt-Shift function even more seamless, both the lens mount as well as Tilt-Shift section may be rotated on the optical axis. The Tilt-Shift section may be rotated left by 90 degrees (with 30 degree adjustment), while mount of the lens may be rotated both in left and right direction by 90 degrees, also with 30 degree adjustment.
Samyang T-S 24mm 1:3.5 ED AS UMC will be available with mounts for Canon EF, Nikon F, Pentax K and Sony A.
Specification
Manufacturer Samyang Optics
Model Samyang T-S 24mm F/3.5 ED AS UMC
Lens type Wide angle Tilt / Shift lens for Full frame or cropped sensors
Focal length 24 mm
Maximum aperture F/3.5
Min aperture F/22
Angle of view 59.9 deg. (56.9 deg. for APS-C/DX)
Min focusing distance 0.20m
No. of diaphragm blades 8
Focus type MF (Manual Focus only)
Lens construction 16 element, 11 groups (2x Aspheric elements)
Dimensions 110.5 - 113mm x 86.0mm
Weight ~ 680 g
Lens Rotation Maximum Tilt Amount:+/- 8.5 deg; Maximum Shift Amount: +/- 12mm. Between Tilt and Shift Rotation: 90 deg Left (click stop for every 30 deg step). Mount Rotation: 90 deg Left and Right (click stop for every 30 deg step).
Filter Size: 82mm
Available mounts Canon, Nikon, Sony A-mount, Pentax
http://www.samyang.co.uk/samyang-t-s-24mm-f35-ed-as-umc-lens.html
http://www.samyang.pl/index.php/pl/samyang-t-s-24-mm-f35
Edited on Sep 07, 2012 at 04:22 PM · View previous versions
Mar 05, 2012 at 05:59 AM
wayne seltzer
p.1 #2 · Samyang 24mm tilt-shift lens - now announced
Thanks! Should be interesting!
Mar 05, 2012 at 06:44 AM
paulesko
p.1 #3 · Samyang 24mm tilt-shift lens - now announced
It is very interesting...
Mar 05, 2012 at 06:48 AM
trenchmonkey
p.1 #4 · Samyang 24mm tilt-shift lens - now announced
...this could be huge!
Mar 05, 2012 at 06:54 AM
ulrikft2
p.1 #5 · Samyang 24mm tilt-shift lens - now announced
Something tells me that huge is the right word indeed monkey
Mar 05, 2012 at 06:58 AM
mirkoc
p.1 #6 · Samyang 24mm tilt-shift lens - now announced
This is interesting AND huge!
Mar 05, 2012 at 07:17 AM
xbarcelo
p.1 #7 · Samyang 24mm tilt-shift lens - now announced
And probably not that affordable, either… considering they seem to be valuing themselves a little more…
Mar 05, 2012 at 07:22 AM
ManWearPants
p.1 #8 · Samyang 24mm tilt-shift lens - now announced
Nice strategy since they are making affordable manual focusing lenses. This is really a nice move to increase price. Let's hope it is better than the TS-E 24 mkI and close to the mkII but still cost cheaper than the mkI.
Mar 05, 2012 at 07:39 AM
LightShow
p.1 #9 · Samyang 24mm tilt-shift lens - now announced
One can only hope.
Mar 05, 2012 at 08:15 AM
mikeleslie
p.1 #10 · Samyang 24mm tilt-shift lens - now announced
hmmm that would be cool. This one is cool in 80mm
http://lensbaby.com/video.php?id=23
bringing us the T/S look for less.
...mikel
Mar 05, 2012 at 09:07 AM
mikeleslie
p.1 #11 · Samyang 24mm tilt-shift lens - now announced
I meant the Edge 80 optic...
I would love wider too.
...m
Mar 05, 2012 at 09:11 AM
Alf Beharie
p.1 #12 · Samyang 24mm tilt-shift lens - now announced
Sigma could learn a thing or two from them...Not everyone wants lenses with AF
Mar 05, 2012 at 10:15 AM
dcad10
p.1 #13 · Samyang 24mm tilt-shift lens - now announced
I hope you are wrong
Mar 05, 2012 at 10:55 AM
Smiert Spionam
p.1 #14 · Samyang 24mm tilt-shift lens - now announced
Something functional with decent mechanical controls would be very welcome. The LensBaby stuff and the cheap tilt adapters for NEX and m43 are ok toys, but once you get tired of that gimmick, they're pretty useless.
Mar 05, 2012 at 11:11 AM
RustyBug
p.1 #15 · Samyang 24mm tilt-shift lens - now announced
Having recently acquired the 24L TS-E II ... this will prove to be very interesting to see how they follow suit and where they land.
I'm guessing the price right around $1,450 ... well above the TS-E ver. 1 used market value and while still below the TS-E II used market value ... assuming the optical quality sits between the two as well. If so, it should be a very nice marketing move ... 90mm TS to follow
Mar 05, 2012 at 12:04 PM
obik
p.1 #16 · Samyang 24mm tilt-shift lens - now announced
I'm kinda skeptical of this one. Samyang haven't really made an effort to correct the distortion in their wide angles before now, and their 24/1.4 (at least the mark I) isn't exactly a showstopper. Personally, I hope they bring out a 90mm f2.8 Macro TS. That'd be a killer, Especially if they bothered to put an electronically controlled aperture in it.
Mar 05, 2012 at 12:16 PM
RustyBug
p.1 #17 · Samyang 24mm tilt-shift lens - now announced
Well, even the Canon 24/1.4 pales somewhat compared to the 24/3.5L TS-E II. Something about optical trade-offs to get that 1.4 ... guessing not an indication of Samyang as much as optics in general.
+1@ 90/2.8 Macro TS w/elec aperture ... like I need another 80-110 lens
Mar 05, 2012 at 12:27 PM
FlyPenFly
p.1 #18 · Samyang 24mm tilt-shift lens - now announced
Well besides the 35mm F1.4 they haven't really made anything that noteworthy IMO. That lens is a huge bargain.
Otherwise their 85mm F1.4 is OK but kind of sucks, their 14mm F2.8 is interesting but horribly made, has tremendous vignetting, and is gigantic.
Mar 05, 2012 at 12:41 PM
mirkoc
p.1 #19 · Samyang 24mm tilt-shift lens - now announced
I am not so sure about the electronically controlled aperture because of possible focus shift when stopping down.
Mar 05, 2012 at 01:09 PM
PB_James
p.1 #20 · Samyang 24mm tilt-shift lens - now announced
It's got to have the tilt and shift mechanisms independently alignable (unlike Nikon's PC-E lenses). Otherwise, what's the point? For it to really be a hit, it's got to be sub $1k. I absolutely think both are possible, and I'm hopeful that they pull it off.
Mar 05, 2012 at 01:27 PM
       2       3       4       5       end
       2       3       4       5       end
