Archive 2012 · Remote Camera Cable
Two23
p.1 #1 · p.1 #1 · Remote Camera Cable
I'm using a Nikon d300 with 10-pin remote socket, and use CyberSync triggers to remote fire the camera. I've been using a $30 cable to connect the trigger to the camera. This one has a little switch that I push to engage the trigger or alternately view photos on camera LCD. I've not been happy with this cable. I find it fiddly, as if it has a short in it. (Second cable I've had.) The other thing is I have to pump the trigger twice to get it to fire. (I have AF turned off.) I need something more reliable. Suggestions? I'm using the remote release to fire the camera so I can take photos of myself in a scene. I'm also firing a set of flash from my camera using CyberSync CST in the hotshoe, tuned to different channel.
Kent in SD
Feb 23, 2012 at 02:38 PM
Monkey Falls
p.1 #2 · p.1 #2 · Remote Camera Cable
I use FlashZebra products with great success.
FlashZebra
If that's what you are already using, I would recommend contacting FlashZebra. FlashZebra customer support is the best.
If it's not what you are using, then I would recommend that you give it a try.
Feb 23, 2012 at 03:18 PM
Two23
p.1 #3 · p.1 #3 · Remote Camera Cable
That's the one I currently have.
Kent in SD
Feb 23, 2012 at 03:49 PM
pbjunkiee
p.1 #4 · p.1 #4 · Remote Camera Cable
I make my own. I learned from the master himself, Shawn Cullen.
Feb 23, 2012 at 05:41 PM
Two23
p.1 #5 · p.1 #5 · Remote Camera Cable
Well, unfortunately for me they moved this post from sports, where there actually are people who use remote fired cameras routinely, to the Nikon board where the majority are likely to be asking, "What's a Cybersync?" I might be screwed here.
Kent in SD
Feb 24, 2012 at 02:51 AM
NightOwl Cat
p.1 #6 · p.1 #6 · Remote Camera Cable
http://www.bhphotovideo.com/c/product/650563-REG/Zeikos_ZE_RMC30_ZE_RMC30_Remote_Switch.html
Works well on my D1h's, D1x, D200, D300s. I also have a Yong Nuo knockoff, and a Nikon MC-20 purchased used.
Kent in SD
Feb 24, 2012 at 03:17 AM
Two23
p.1 #7 · p.1 #7 · Remote Camera Cable
Thanks for the thought, but the Cybersyncs I already have are camera triggers, and also flash triggers. They have 150 yard range. The nine dollar deal doesn't have much range, especially outdoors.
Kent in SD
Feb 24, 2012 at 04:25 AM
