What are the criteria?
Archive 2012 · critique wanted
Julian Nell
p.1 #1 · critique wanted
I was wondering what could be better about this image.
Feb 20, 2012 at 03:22 AM
cgardner
p.1 #2 · critique wanted
More color contrast between background and bug would make it stand out more. A tighter crop would also help for that. Less leaf, more bug = more impact.
Edit: added illustration..
Above I lightened the background to make the bug contrast more. I'm not suggestion you edit your shot this way, but in future when shooting ask yourself: 1) What is most important here? and 2) How can I make it contrast from the background and be noticed?
In the tighter crop I played the bottom right edge off the bottom right corner of the frame and the curve of the top antennae off the upper right to create a sense of connection between the content and the frame.
Edited on Feb 20, 2012 at 01:14 PM · View previous versions
Feb 20, 2012 at 03:34 AM
Dougo
p.1 #3 · critique wanted
Hi Jullian,
I had a shot at your image,
I added a curves layer and changed the blending mode to Multiply, then on the mask I used a black brush with a small flow rate about 5% and lightened the bug a bit.
Then I cropped it and applied a small amount of sharpening.
Cheers Ray
Feb 20, 2012 at 07:25 AM
RustyBug
p.1 #4 · critique wanted
Nice rework ... digging the leading line from the corner crop
Feb 20, 2012 at 11:14 AM
fracas
p.1 #5 · critique wanted
I like the Dougo's more contrasty rework
I would crop a bit more the bottom and maybe I'd leave the top part untouched
Also: clone away that small thing on the bottom left corner
Cheers
Francesco
Feb 20, 2012 at 11:48 AM
sbeme
p.1 #6 · critique wanted
I think Ray (dougo) has very nicely illustrated the kind of rework suggested.
Nice!
scott
Feb 20, 2012 at 01:00 PM
Julian Nell
p.1 #7 · critique wanted
Thanks for the suggestions.
Julian
Feb 20, 2012 at 04:34 PM
Julian Nell
p.1 #8 · critique wanted
Does look good?
Edit: Does it need to be warmer?
Feb 20, 2012 at 04:55 PM
Julian Nell
p.1 #9 · critique wanted
Here is a warmer version, is it better?
Feb 20, 2012 at 07:28 PM
AuntiPode
p.1 #10 · critique wanted
Warmer is better to my eyes, but it's subjective.
Feb 20, 2012 at 10:25 PM
Bob Jarman
p.1 #11 · critique wanted
@Julian Nell,
The only thing that really matters is which you prefer, it is your vision. We can re-work and suggest; the final choice is yours.
FWIW, I prefer something between.
regards,
Bob
Feb 20, 2012 at 10:31 PM
Julian Nell
p.1 #12 · critique wanted
I agree that something in between and I actually prefer the more wide open version but I don't have Photoshop to clone out that small little dirt or whatever it is.
Julian
Feb 20, 2012 at 10:46 PM
Julian Nell
p.1 #13 · critique wanted
This is more what I like.
Feb 20, 2012 at 11:06 PM
cgardner
p.1 #14 · critique wanted
The problem is lack of separation between the brown bug and the the brown background. Because the background is so large relative to the size of the bug the bug disappears into it. That's what its coloring is designed to do in nature, but that makes for a less interesting photo.
Global adjustments of the color shift bug and background together so there's no net increase in contrast. That's why in my edit I masked out the bug and leaf and changed the background in CS5.
Absent the ability to do that with your editing program one solution would be to crop tight and show more bug than background then use the dodging tool to lighten the tone of the background.
Feb 21, 2012 at 12:01 AM
Julian Nell
p.1 #15 · critique wanted
I only have the viewNX software right now and I don't think that option is on my software.
Julian
Feb 21, 2012 at 12:49 AM
Bob Jarman
p.1 #16 · critique wanted
As a very disappointed Capture NX user (through 2.2.6) in the way Nikon has mismanaged that application (which has the capacity to be better than CS5 in color rendition if they'd only done it right), I suggest you consider LR 3 Academic Version if you can qualify ($89). I am not sure what else is available at a reasonable cost.
Bob
Feb 21, 2012 at 01:03 AM
Julian Nell
p.1 #17 · critique wanted
Thanks I might be able to figure that out.
Julian
Feb 21, 2012 at 02:29 AM
