Archive 2012 · UV Filter Test Results
bushwacker
p.1 #1 · UV Filter Test Results
UV Filter Test Results for your Canon Lenses.
Hope these results help you decide what to buy.
http://www.lenstip.com/113.4-article-UV_filters_test_Description_of_the_results_and_summary.html
I'll post this one too in Alternate gears\ General.
Feb 19, 2012 at 01:11 PM
EB-1
p.1 #2 · UV Filter Test Results
Are those the same old results or has it been updated recently? I don't see the newer B+W filters so perhaps not. I also don't see any tests of the IQ by MTF or anything other than flare and spectral transmission.
Feb 19, 2012 at 01:26 PM
bushwacker
p.1 #3 · UV Filter Test Results
the link has flare tests too... almost all of them have flares except for the marumi brand.
Feb 19, 2012 at 02:15 PM
Mike K
p.1 #4 · UV Filter Test Results
Date is 2009, I believe these are original data.
Since there is no real need for UV filters any more the original CP tests by lenstip are a lot more interesting, and more controversial, if you haven't seen them before:
http://www.lenstip.com/115.1-article-Polarizing_filters_test.html
and the supplement
http://www.lenstip.com/119.5-article-Polarizing_filters_test_-_supplement_Hoya_HD_CIR-PL_72_mm.html
Feb 19, 2012 at 09:17 PM
seam4444
p.1 #5 · UV Filter Test Results
Since there is no real need for UV filters any more....
Here we go again!!!
I have seen this stated many times here on FM. My question is: if you scratch the front element, how much does it cost to get fixed? When I called Canon and asked about repairing a 85L, they said the flat rate for "L" lenses was $365. I'm not sure if that means that a front element cost that much, but if it does, that is an expensive front element!
Feb 20, 2012 at 01:10 AM
