Archive 2012 · D700 8 fps???
Grantland
p.1 #1 · D700 8 fps???
hi,
trying to learn nikon and you should know learning never came easy to me.
so please . . .
i hear people talking the D700 can do 8 fps but when i put the md-10 grip on the body the menu says i can adjust the fps from like 2-7. no 8
am i missing something?
grant
Feb 10, 2012 at 07:14 PM
Trevorma
p.1 #2 · D700 8 fps???
Might depend on the battery type.
I have an EN-EL3 for my D700 and it shows 8fps in the menu. If I use the battery tray for AA batteries no matter what type I use I never get more than 7, and after a few minutes the power drops of HUGE!!!!!!!
Feb 10, 2012 at 07:19 PM
honorerdieu
p.1 #3 · D700 8 fps???
Are you using 8 AA batteries or the the rechargeable EN-EL4/a in the battery pack? Make sure the settings are for high continuous shooting mode (CH).
Trevorma
p.1 #4 · D700 8 fps???
Oops, my post should have read the EN-EL4 battery.....
That reminds me I am confused by Nikons battery naming !!!!!
Feb 10, 2012 at 08:13 PM
RoyC
p.1 #5 · D700 8 fps???
Either set the body up to run off of the en-el4a first, or take the battery out of the body. Then all should be well.
Feb 10, 2012 at 09:21 PM
Grantland
p.1 #6 · D700 8 fps???
thank you
Feb 10, 2012 at 11:07 PM
sjms
p.1 #7 · D700 8 fps???
you simply need to supply 11.1 vdc. thats an EN-EL4 or EN-EL4a battery pack. to use them you also need a BL-3 battery chamber cover.
Feb 10, 2012 at 11:19 PM
lou f
p.1 #8 · D700 8 fps???
if you put 12v in you get 9 fps.
Feb 11, 2012 at 11:00 AM
nikt
p.1 #9 · D700 8 fps???
The menu you are refering to is the CL Mode Shooting Speed
CL is Continous Low Speed shooting. it is selectable from 2-7 shots.
The CH mode is Continuos High and will shoot (upto 8 fps with the grip.
Feb 11, 2012 at 11:12 AM
trenchmonkey
p.1 #10 · D700 8 fps???
Uh, NO
Feb 11, 2012 at 02:15 PM
Wm. Manther
p.1 #11 · D700 8 fps???
trenchmonkey wrote:
Uh, NO
Oh, what the heck. Hook that baby up to 220V and you'll have a GE mini gun. That'll get some one's envy going
Feb 11, 2012 at 02:35 PM
trenchmonkey
p.1 #12 · D700 8 fps???
Feb 11, 2012 at 02:38 PM
lou f
p.1 #13 · D700 8 fps???
trenchmonkey wrote:
Uh, NO
;o)
http://www.youtube.com/watch?v=EbVKWCpNFhY
Feb 11, 2012 at 02:42 PM
sjms
p.1 #14 · D700 8 fps???
yes mine goes to 11 too.
Feb 11, 2012 at 03:22 PM
EB-1
p.1 #15 · D700 8 fps???
In the old days one could "overclock" film cameras by increasing the voltage/current to the motor drive sometimes, but that is not so with digital. The sensor and image processing have specific design limits.
Feb 11, 2012 at 03:36 PM
joshn
p.1 #16 · D700 8 fps???
You need to use rechargeable batteries, not Duracell or other alkaline batteries. I use Eneloops personally and it works beautifully at 8fps.
Feb 11, 2012 at 03:54 PM
fluteboi
p.1 #17 · D700 8 fps???
So 8fps is also possible using rechargeable AA batteries? and not just the EN-EL4 and EN-EL4a?
Feb 12, 2012 at 06:57 AM
Antonio Tiki
p.1 #18 · D700 8 fps???
Yes, and you can use Alkaline batteries.
Feb 12, 2012 at 09:15 AM
davidnholtjr
p.1 #19 · D700 8 fps???
Grantland wrote:
hi,
so please . . .
grant
That adjustment setting is for the CL mode to set what fps you want in CL. CH mode is for 8fps with the grip and AA batteries or the battery from the D3 can be used.
Feb 12, 2012 at 03:10 PM
Grantland
p.1 #20 · D700 8 fps???
i used 8 rechargeable batteries (2500 mhs) and it worked. but. . . for some reason the battery pack didn't stay connected in camera and it would go back to 5 fps. frustrating.
Feb 12, 2012 at 05:33 PM
