       2       3       end
Archive 2012 · Looking for a wildlife setup
OCphotography
p.1 #1 · Looking for a wildlife setup
I want to start some serious wildlife photography, but funds are a bit limited.
Question is, which setup would you recommend?..
Canon EOS 7D + 300mm f/2.8 IS
or
Canon EOS 1D Mark IV + 300mm f/4.0 IS
I already have the Canon EOS 5D Mark II, I am not sure if I should keep that and add a 300mm f/2.8 IS to that. I am aware of the lower fps and limited AF.
Jan 31, 2012 at 08:33 AM
Pixel Perfect
p.1 #2 · Looking for a wildlife setup
What do you use your 5D II for? If you intend to do a lot of landscape, portrait, architecture type work then definitely keep it. If you want to mainly concentrate on wildlife then you could sell the 5D II to help fund an alternate kit.
The best entry level high quality option I can recommend with maximum flexibility would be 7D + 100-400L IS. The 100-400L has excellent IQ, a very short mfd and decent AF. I believe 400mm is the minimum FL for serious wildlife work. This would keep your cost to around $3K and give you and excellent startup kit. The alternate lens that has the IQ and fast AF is the 400 f/5.6L, which is a bit cheaper than the zoom. IQ is a tad better, but AF is a fair bit faster for action work. But it's much more specialised.
The next step up from this is going to be much dearer and you are looking at the superteles. I can vouch for the fact the 300 f/2.8L IS work extremely well with both a 1.4x TC and 2x TC, so gives you up to 600mm of FL and coupled with the 7D you will have some very good reach. I used the 300 + 2x for a couple of years on a 1D II and was very happy with the results. Now I use the 7D + 300 + 1.4x quite frequently for birding as it's still got very fast AF and is quite easy to hand hold for extended periods for BIF's.
The 1D IV is obviously a step up from the 7D but I'd recommend putting more money on the glass. A 7D + 300 f/2.8 will IMO do a better job than a 1D IV + 300 f/4 and the f/2.8 lens trashes the slower lens when you start adding TC's to the equation.
The third option if you sell the 5D II would be to replace the 300 f/2.8 option with a 500 f/4L IS.
Jan 31, 2012 at 08:56 AM
Dave Bachrach
p.1 #3 · Looking for a wildlife setup
I have the 7D and the 300 f2.8 IS, and it's a great combo for me.
Jan 31, 2012 at 09:32 AM
p.1 #4 · Looking for a wildlife setup
Start with the 7D and 300/2.8L IS. Then get a 1.4x Extender Mk III. Then get a 1DIV. Then get a 500/4 L IS. You get the picture...
Edited on Jan 31, 2012 at 02:58 PM · View previous versions
Jan 31, 2012 at 11:03 AM
Pixel Perfect
p.1 #5 · Looking for a wildlife setup
jcolwell wrote:
Start with the 7D and 30/2.8L IS.
That 30 f/2.8 won't be that good for wildlife unless he's doing macro
Jan 31, 2012 at 12:43 PM
OwlsEyes
p.1 #6 · Looking for a wildlife setup
The 300mm f2.8IS lens w & w/out converters is an amazing lens. This is a great way to start your wildlife kit, & the lens should outlive your current & future bodies. Buy the lens w/ a 1.4x & pair it w/ a 7D or 1DmkIIn & practice! You'll love what you can do with.
To see a library of wildlife work from East Africa to Costa Rica, check out my blog & dig through the archives. The majority of wildlife work was shot w/ my 300 f2.8 IS & a 7D or 1DII
Http://bruceleventhal.blogspot.com
Regards, Bruce
Jan 31, 2012 at 01:03 PM
kbperry810
p.1 #7 · Looking for a wildlife setup
It's a tough vote for me as I'm almost in the same boat. (though it's really not a bad "boat" to be in!)
I already have the 100-400, so was leaning more towards the 1DIV...
Though I've also been tempted by the 7D and 300mm 2.8 with 1.4x and 2x TC combo as well. (of course a used 1DIIn or 1D3 is on my radar too)
Decisions, decisions, decisions...
Jan 31, 2012 at 01:44 PM
Snopchenko
p.1 #8 · Looking for a wildlife setup
How about the new Sigma 120-300 OS? Just an option.
Jan 31, 2012 at 01:56 PM
mco_970
p.1 #9 · Looking for a wildlife setup
Pick up a 500L and put it on your 5D2. Then add a 1D or 7D later if you wish. Glass first.
Jan 31, 2012 at 02:12 PM
OwlsEyes
p.1 #10 · Looking for a wildlife setup
This is the best lens a stationary wildlife shooter can have. If mobility (long hot hikes) and finances don't limit your options, then you can't beat the 500IS. If you plan to travel & hike w/ your gear, the 500IS will be a burden!
Cheers,
Bruce
Jan 31, 2012 at 02:35 PM
alundeb
p.1 #11 · Looking for a wildlife setup
What is the longest focal length you have used until now?
Is the 500 4 IS at all within reach, financially?
Jan 31, 2012 at 02:42 PM
galenapass
p.1 #12 · Looking for a wildlife setup
+1
Jan 31, 2012 at 02:49 PM
jpeter
p.1 #13 · Looking for a wildlife setup
I have worked to build up a better wildlife kit over the last several years. I presently have a 7D, 200f2.8, ef1.4x, 300f4is, & 500f4. Lenses like the 500f4 have their use along side something more compact like the 300f4. I don't see a compelling reason to get the 300f2.8 over the 300f4 unless you want to use a 2x teleconverter. The portability of the 300f4 is an important attribute.
I generally do my wildlife shooting with my longest lens on the 7d, but have used the 5d2 from time to time. A great "non-photo" vacation/travel setup for me (if wildlife shooting is a possibility) is a 35-70 zoom, 1.4x, 300f4 & 5d2.
JP
Jan 31, 2012 at 02:56 PM
p.1 #14 · Looking for a wildlife setup
galenapass
p.1 #15 · Looking for a wildlife setup
I also have the 300mm and 500mm f/4 and find that this combo works quite well. As noted above, for wildlife I see no need for a 300mm f/2.8. Sports...now that's a different story. One attribute that many forget is the short MFD of the 300mm f/4 which yields pseudo macro shots when needed. I find this to be very useful.
Jan 31, 2012 at 03:38 PM
M Vers
p.1 #16 · Looking for a wildlife setup
galenapass wrote:
+1
+2
Jan 31, 2012 at 03:43 PM
abqnmusa
p.1 #17 · Looking for a wildlife setup
I choose the 7D + 300mm F4 IS + 1.4X III + 400mm F5.6 + monopod + extension tubes
this combo is portable for hiking
cost was less that the 1D IV body without lens
I understand 1D IV is "pro body" but too expensive
Jan 31, 2012 at 04:19 PM
sritri
p.1 #18 · Looking for a wildlife setup
I just about started late last year with a 400/5.6 to begin with, then traded it for a 300/4 IS as I don't have steady hands. Thought a lot about trading my 7D & 5D-II for a 1D-IV but went for a 500/4 IS instead. 300/4 on the 7D and 500/4 on the 5D-II seems working for me though I have taken this combo out only once and have no photo to show
Jan 31, 2012 at 04:47 PM
Sharona
p.1 #19 · Looking for a wildlife setup
Regardless of the lens decision, it's always good to have a back-up body, so your 5DII would be useful unless you got another 7D. The 5D would be great for landscapes, low light shooting, and sleeping animals....
In Africa, I use the 100-400 90 percent of the time.
Jan 31, 2012 at 05:08 PM
Don Clary
p.1 #20 · Looking for a wildlife setup
A 7D + 300 f/2.8 ... and the f/2.8 lens trashes the slower lens when you start adding TC's to the equation.
I agree 7D and 100-400 is best starter setup. Below is 300f4L IS and 1.4XII, hand held in very low level Falkland Islands light.
full image
100% crop
Jan 31, 2012 at 05:22 PM
       2       3       end
       2       3       end
