Archive 2012 · 70-200/4L IS Tripod Collar
J Williams
p.1 #1 · 70-200/4L IS Tripod Collar
Does anyone know if the tripod collar for the 70-200/4L IS is the same as the one used for the non-IS version of this lens? Thanks.
Jan 28, 2012 at 02:43 PM
C Parish
p.1 #2 · 70-200/4L IS Tripod Collar
I believe the barrels are the same between those two lenses, so yes, same collar.
Cheers
Jan 28, 2012 at 02:52 PM
omarlyn
p.1 #3 · 70-200/4L IS Tripod Collar
The listed collar for the IS version is the 'A II W' and the one for the non-IS is 'A II B'…I have no idea if they are interchangeable but they are listed as separate collars on the Canon USA site.
Omar
Jan 28, 2012 at 03:04 PM
Geert Koning
p.1 #4 · 70-200/4L IS Tripod Collar
They are the same, I had a tripod collar for the non IS wich I now use for the IS version.
Geert
Jan 28, 2012 at 03:44 PM
J Williams
p.1 #5 · 70-200/4L IS Tripod Collar
I think I found my answer on the B&H website:
The Canon Tripod Mount Ring A-2 is the tripod collar for the EF 70-200mm f/4L (both IS and non-IS versions)
Apparently they are the same. I actually have the black version for the 200/2.8, but it works on my 70-200 non IS so it should work on the IS version as well. Thanks for the replies.
EB-1
p.1 #6 · 70-200/4L IS Tripod Collar
The A Tripod Ring Mount is the same. I have used the use the black one on all four of my compatible lenses (two 70-200/4 300/4, 400/5.6).
Jan 28, 2012 at 03:46 PM
molson
p.1 #7 · 70-200/4L IS Tripod Collar
Omar
The "W" stands for white, and "B" is for black... other than the paint colour, those two collars are identical.
Jan 29, 2012 at 01:54 AM
