Archive 2012 · 1D 2N SDHC ?
jleom
p.1 #1 · 1D 2N SDHC ?
I have the last firmware update and am using a 8gb SDHC but can't find any info that tells me if I can use larger capacity cards?
Thanks for your help.
Leo
Jan 24, 2012 at 01:22 PM
john_edwards
p.1 #2 · 1D 2N SDHC ?
I tried a 16mp Sandisk 30mps hd video card in my 1Ds2 and it works OK, I would think it would in your cam too
Jan 24, 2012 at 01:30 PM
Ian.Dobinson
p.1 #3 · 1D 2N SDHC ?
Leo
with the later firmware SDHC is fine . I dont think there is an upper limit (in the real world) to the size you can use . not so sure about SDXC though.
Jan 24, 2012 at 02:11 PM
mco_970
p.1 #4 · 1D 2N SDHC ?
Leo
I use 16g SDHC in my 1D2n, no problem. Never thought about not being able to use it.
Jan 24, 2012 at 02:29 PM
Gunzorro
p.1 #5 · 1D 2N SDHC ?
I use 16GB SDHC in my 1D2 and 1Ds2 -- no problems.
Jan 24, 2012 at 03:23 PM
jleom
p.1 #6 · 1D 2N SDHC ?
Thank you for the info. I found that with the firmware update it would recognize 4 & 8gb cards but didn't say anything about larger cards. Thought maybe it was because it was long enough ago that larger cards weren't readily available. Good to know.
Thanks again
Leo
Jan 24, 2012 at 03:29 PM
Daigen-za
p.1 #7 · 1D 2N SDHC ?
That was my thought as well when considering 32GB cards for my 1Ds MkII (which by the way came out before the 1D MkIIn).
I just inserted the 32GB SDHC card in my 1D MkII and the camera recognizes the card - estimating ~2940 shots (varies slightly depending on ISO set).
Jan 24, 2012 at 11:32 PM
patrick_morris
p.1 #8 · 1D 2N SDHC ?
I have a 32gb in my 1d2n as well with no problems
Jan 25, 2012 at 09:39 PM
Rich Swanner
p.1 #9 · 1D 2N SDHC ?
My sd card is slower then the cf at emptying the buffer I use it as a backup or a one shot situation only. No fast fps...Rich
Jan 26, 2012 at 04:34 AM
brez
p.1 #10 · 1D 2N SDHC ?
32GB works in my 1DIIn
Mike
Jan 27, 2012 at 12:49 AM
