PeaktoPeek Offline Upload & Sell: Off
p.1 #3 · Contax / Yashica Zeiss lens compatibility on 5D Mark 2 confusion | |
FWIW, I never had any issues using those lenses on my 5D. I initially had trouble with the 28 but after measuring the adapter thickness with a caliper I noticed it was too thin. After getting a different adapter there were no issues. They note that the adapter thickness that is technically correct is 1.5mm, however, I found that the best measurement was 1.42mm -- I think they noted the same thing (1.425). You should be just fine if you get an adapter with the right thickness, I have also known many others who have used Contax lenses without issue on 5D and 5DII cameras.
Paul
