Archive 2012 · Monopod/head setup for Canon 800mm
gschrade
p.1 #1 · Monopod/head setup for Canon 800mm
I am looking to get a monopod and head for a Canon 800mm lens. Any suggestions for this heavy-duty setup?
Thanks in advance, George
Jan 11, 2012 at 02:52 PM
Ben Horne
p.1 #2 · Monopod/head setup for Canon 800mm
In a perfect world, I'd say always use a tripod with that lens, but if you have a specific need for amonopod, I'd suggest a Gitzo 5 series carbon fiber monopod, then attach a Quick release attachment for the top --- no head.
Jan 11, 2012 at 03:00 PM
gschrade
p.1 #3 · Monopod/head setup for Canon 800mm
Thanks Ben. I plan on using a tripod most of the time, but wanted to take the lens hiking sometimes and did not want to carry the tripod and gimbal head while hiking, so was looking for a monopod setup. Any suggestions on the quick release attachment?
George
Jan 11, 2012 at 03:05 PM
AGeoJO
p.1 #4 · Monopod/head setup for Canon 800mm
RRS has a great monopod head, the MH-1 Pro. The drawback is its price.... Check it out: http://reallyrightstuff.com/ProductDesc.aspx?code=MH-01-Pro&type=0
Jan 11, 2012 at 03:16 PM
InternetJunky
p.1 #5 · Monopod/head setup for Canon 800mm
+1
For the monopod, definitely go for a carbon fiber model. I started with a cheaper model initially for my 600mm and it warped and nearly broke on me. I prefer the monopods with the clasps you can flip up/down to extend/retract, and others prefer the ones you twist. It comes down to personal preference.
There is little need for a head on the monopod though. I use an arca swiss quick release adapter on the top of my monopod. I can hike with my 600mm over my shoulder and have no fear of the lens falling off.
Cheers,
Harry C
NikkorAIS
Account Locked
p.1 #6 · Monopod/head setup for Canon 800mm
If I have to use a mono-pod with super-telephoto's I still use my Wimberly with the mono-pod.
Being able to tilt up and down with out leaning the stick is a huge plus.
Being able to tilt the Camera/lens for transport over the shoulder is also very nice if your walking any sort of distance.
I just bought a manfrotto 681 and combined with my Wimberly it's a workable solution with super telephoto's. I find the way this mono-pod changes levels with the levers is much easier one handed than the twisting method of my last one.
I still think using a mon pod is a less than perfect solution with focal length's over 300 mm, but having the right mono-pod with the Wimberly makes it tolerable.
Nikkor 800 5.6 IF-ED AI-S on D2H on Mono-pod and Wimberly
Gregory
Jan 11, 2012 at 03:34 PM
gschrade
p.1 #7 · Monopod/head setup for Canon 800mm
Thanks Harry and Gregory
Jan 11, 2012 at 03:51 PM
gschrade
p.1 #8 · Monopod/head setup for Canon 800mm
Does look like a nice setup.
Thanks, George
Jan 11, 2012 at 03:57 PM
Sizeman
p.1 #9 · Monopod/head setup for Canon 800mm
That is the set up to get - I shoot with that set up on their large monopod with the 400mm, 600mm and the 800mm when needed. THe manfrotto monopods do not hold up as well (680/681etc) been there done that. If you use the plates then it is easy to mount on wither the MH-01 or the wimberly gimbal
good luck and have fun
Steve
Jan 11, 2012 at 04:10 PM
gschrade
p.1 #10 · Monopod/head setup for Canon 800mm
Thanks Steve
Jan 11, 2012 at 04:25 PM
