enroute Offline Upload & Sell: Off
| p.1 #1 · FS: Eizo Coloredge CG221 Monitor | |
Item still Available
Price: $950.00 Payment method: Cash or Credit Card transaction only. Item condition: 9+ Shows little or no signs of wear Shipping instructions: Includes shipping & insurance lower 48.
The ultimate graphics monitor! Excellent condition. 12,423 hours. No blown out pixels. No noticeable wear on monitor or casing.
Product Highlights
• DVI-I + DVI-I
• 1920 x 1200
• 400:1 Contrast
• 200cd/m2 Brightness
• 170°/170° Viewing Angle
• 30ms Response Time
• 16.7 Million Colors
• USB 2.0 Hub
• Monitor Hood
The ColorEdge CG221 22.2" Widescreen LCD Display from EIZO is a high-quality monitor built with video professionals and graphic designers in mind. The monitor features a high 400:1 contrast ratio, a wide 170°/170° viewing angle, and a 30ms response time.
The monitor is designed for use in environments where accurate color is essential. It features a factory calibrated gamma, a monitor hood, brightness stabilization, and ColorNavigator calibration software. The monitor is a flat panel, which saves desk space. That, along with other features, makes it a great choice for video editors and graphic designers alike.
True Color for Professionals
This display features professional-level color controls that allow you to use it when working with color correction for video or print graphic design. This makes the monitor an ideal choice for professional designers and editors. The monitor features 16-bit processing for exceptional color and grayscale reproduction.
ColorNavigator Calibration Software
The included software for Windows or Macintosh allows you to perform 10-bit hardware color calibration on your monitor. It requires an X-Rite or ColorVision measurement device to function; neither of which are included with the display.
Factory Adjustment of Gamma
EIZO calibrates this monitor to produce a gamma value of 2.2. Users who require a different level of gamma can use the monitor's 10-Bit Look-Up Table (LUT) to adjust the values from 1.0 to 2.6 when using a digital connection.
Brightness Stabilization Function
The brightness stabilization function helps to maintain a consistent brightness when using the monitor. It uses a drift correction sensor as well as temperature monitoring to ensure consistent brightness.
USB 2.0 Hub
The monitor features an integrated 2-port USB 2.0 hub. Simply connect the monitor to your computer via USB 2.0 and you'll be able to connect two USB 2.0 devices directly to the display.
Wide Viewing Angle
The monitor features a 170° horizontal viewing angle and a 170° vertical viewing angle, making it easy to view the display from almost any angle.
Small Footprint
The monitor's small footprint and ability to be wall-mounted or arm-mounted help conserve often-scarce space on your desk. The monitor ships mounted on a stand that supports tilt and height adjustment for enhanced ergonomics.
$5,034 new at B&H
Price: $5,600.00 Payment method: Cash or Credit Card transaction only. Item condition: 9+ Shows little or no signs of wear Shipping instructions: Includes shipping & insurance lower 48.
24,242 Shutter actuations. Excellent condition. Cash or credit card payment
