Archive 2012 · 7D at ISO 1600
beanpkk
p.1 #1 · 7D at ISO 1600
I don't usually push the 7D this far but here's one that I think looks good.
kk
IMG_9572 by beanp, on Flickr
Jan 02, 2012 at 03:10 AM
Netgarden
p.1 #2 · 7D at ISO 1600
Pretty darn good! Really nice job, those little guys move around pretty fast! Flash?
Jan 02, 2012 at 03:34 AM
eskimochaos
p.1 #3 · 7D at ISO 1600
PP would liven it up.
reno.peterson
p.1 #4 · 7D at ISO 1600
I find the 7D to be very good @ normal viewing sizes and in print from a quality print shop/service.
7D and 300 f/4L Non-IS lens...Great combo!!!
  Canon EOS 7D    300 mm    f/4.0    1/800 sec    1600 ISO    0.0 EV
Jan 02, 2012 at 04:21 AM
Imagemaster
p.1 #5 · 7D at ISO 1600
Don't know why you would be concerned about using 7D at ISO 1600:
  Canon EOS 7D    400 mm    f/11.0    1/250 sec    1600 ISO    0.0 EV
  Canon EOS 7D    500 mm    f/6.7    1/2000 sec    1600 ISO    0.0 EV
  Canon EOS 7D    500 mm    f/4.5    1/2000 sec    1600 ISO    -0.3 EV
  Canon EOS 7D    500 mm    f/6.3    1/2000 sec    1600 ISO    -1.0 EV
Jan 02, 2012 at 04:53 AM
Imagemaster
p.1 #6 · 7D at ISO 1600
  Canon EOS 7D    400 mm    f/6.3    1/320 sec    1600 ISO    -1.0 EV
  Canon EOS 7D    400 mm    f/8.0    1/1250 sec    1600 ISO    -0.7 EV
Jan 02, 2012 at 04:54 AM
jasonpatrick
p.1 #7 · 7D at ISO 1600
awesome shots! You got me saving for that 100-400, Tony.
Jan 02, 2012 at 05:35 AM
arnold1
p.1 #8 · 7D at ISO 1600
These are amazing!! Thank you for sharing them.
Jan 02, 2012 at 05:54 AM
beanpkk
p.1 #9 · 7D at ISO 1600
Great shots all!
netgarden: Yes, I used a flash, although I don't think it made a lot of difference vis-a-vis some I took w/out flash.
eskimochaos: Feel free to apply some PP -- I'm interested in what you would do with the image.
Imagemaster: where are the kingfishers? Just curious. they're fun birds, and I have only seen them in Florida.
Thanks,
k
Jan 02, 2012 at 12:15 PM
Pixel Perfect
p.1 #10 · 7D at ISO 1600
It's hardly pushing the 7D @ ISO 1600. Heck I used my old 1D II at ISO 1600 when needed and 7D is quite a bit better.
Jan 03, 2012 at 01:10 AM
BrianO
p.1 #11 · 7D at ISO 1600
beanpkk wrote: ...eskimochaos: Feel free to apply some PP -- I'm interested in what you would do with the image.
I'm not eskimochaos, but I would only do two things to it; a little noise reduction / blur on the background, and quite a bit of cyan and blue reduction to account for the open sky lighting the scene.
Many outdoor shots are excessively cyan and/or blue for my tastes unless a custom white balance is used. I can tell by looking at known white objects and catchlights in the subject's eyes if correction could be needed.
[Original on top]
Jan 03, 2012 at 05:27 AM
Imagemaster
p.1 #12 · 7D at ISO 1600
1. noise-reduction applied
2. flash lighting in eye removed
3. Topaz sharpening applied
Jan 03, 2012 at 06:24 AM
Imagemaster
p.1 #13 · 7D at ISO 1600
Thanks,
k
Vancouver Island. They are fairly common in the Pacific Northwest.
Jan 03, 2012 at 06:26 AM
BrianO
p.1 #14 · 7D at ISO 1600
Imagemaster wrote: ...flash lighting in eye removed...
Now why didn't I think of that?
Jan 03, 2012 at 06:34 AM
kevindar
p.1 #15 · 7D at ISO 1600
If you dont have to do extensive cropping (more than 50%) you are not underexposed, and you know your way around noise reduction, iso 1600 is very good, and even 3200 is good. this is one that is about iso 3200
Jan 03, 2012 at 07:16 AM
beanpkk
p.1 #16 · 7D at ISO 1600
Imagemaster -- thanks for the word on the kingfishers. They're great birds to watch and photograph!
Imagemaster and BrianO: thanks for the PP examples. I will pay attention to those things next time. I appreciate your time and effort.
all: thanks for the encouraging comments and wisdom on using the 7D at ISO 1600. I'm sure I'll have the opportunity to try it again soon!
kk
Jan 04, 2012 at 03:36 AM
anthonygh
p.1 #17 · 7D at ISO 1600
Amazing bird images posted here....clearly a great mix of talent and gear!!
Can any 7D users comment on the IQ at ISO 10 - 200? Would it be better or are higher settings better on the 7D? Asking because I'm thinking 7D or 1D3 at the moment....my upgrade from a 40D.
PS: That shrimp thing looks really pissed off!!
Jan 04, 2012 at 03:45 AM
BrianO
p.1 #18 · 7D at ISO 1600
anthonygh wrote: ...Can any 7D users comment on the IQ at ISO 10 - 200? Would it be better or are higher settings better on the 7D?
The ISO 100 through ISO 400 images are superb, and even ISO 800 is very clean. I try to shoot at the lowest ISO setting that will give a well-exposed image, because the less amplification applied the higher the signal-to-noise ratio and the cleaner the image, but except in strong shadow areas I can barely notice any difference in image quality between ISO 50 & 100, or between 200 & 400.
In informal testing I actually found ISO 160 to be the best, and 320 to be marginally better than either 200 or 400, so those are the two setting I use unless something else is absolutely needed.
Jan 04, 2012 at 05:49 AM
kevindar
p.1 #19 · 7D at ISO 1600
with every camera, the lower the ISO the better. I can tell the difference between iso 200 and 100 on 7D at 100% before noise reduction. that much said, it is very usuable to 1600, and even at 3200, but have to be more careful with selective noise reduction.
there was a very good article from a birder, comparing the detail produced by the 7D and 1d3, and found even though 7d has slightly more noise per pixel at a given iso, it produces more detail. some say 7D has the second best autofocus in canon lineup (behind 1d4). many say a properly funcitoning 1d3 or even a 1d2 i better.
Jan 04, 2012 at 07:13 AM
ratsnest74
p.1 #20 · 7D at ISO 1600
Imagemaster--How do you get so close to a kingfisher with only 400mm to work with, they never get closer than 100 feet for me?
Jan 04, 2012 at 09:04 PM
