Archive 2011 · Intermittent Rear Control Wheel on 1D
omarlyn
p.1 #1 · Intermittent Rear Control Wheel on 1D
Has anyone ever had trouble with an intermittent rear control wheel on 1D? Has anyone tried to remove the rear control wheel to get to the contact surface OR tried a DIY 'fix' similar to the one for sticking shutter buttons (using alcohol)?
Omar
Dec 31, 2011 at 04:19 PM
omarlyn
p.1 #2 · Intermittent Rear Control Wheel on 1D
Hmmm…anyone?
Omar
Jan 02, 2012 at 04:56 PM
Kafn8td
p.1 #3 · Intermittent Rear Control Wheel on 1D
I used a zero residue contact cleaner on a friends well worn 5D that he thought he would need to send in. Worked like a charm and has been working correctly ever since.
Make sure it's one safe on all electronics and plastics.
Jan 02, 2012 at 05:44 PM
Bob Kane
p.1 #4 · Intermittent Rear Control Wheel on 1D
Maybe a sticking switch contact upper left of the control wheel? Work it a few times.
Jan 02, 2012 at 06:02 PM
omarlyn
p.1 #5 · Intermittent Rear Control Wheel on 1D
Any particular fluid.. Ronsonol, etc?
Omar
Jan 03, 2012 at 11:34 PM
RCicala
p.1 #6 · Intermittent Rear Control Wheel on 1D
It's fairly simple to remove the back - peel up the grips and take out all the screws, lift the back and inch or so, disconnect the flexes. Putting some cleaner on the control wheel assembly from the inside usually works.
I use DeoxIt D. No idea what's in it, but given how effective it is I'm sure it's got all sorts of toxic, environmentally unfriendly chemicals. Stuff works though and it doesn't take very much. Deoxit Gold is, I believe, a gentler, more delicate formula so I don't bother with it.
Jan 04, 2012 at 12:34 AM
Kafn8td
p.1 #7 · Intermittent Rear Control Wheel on 1D
The DeoxIt stuff is what I used.
Jan 04, 2012 at 04:44 PM
omarlyn
p.1 #8 · Intermittent Rear Control Wheel on 1D
OK Great! DeoxIt it is then! Thanks all for the replies.
Omar
Jan 04, 2012 at 05:45 PM
rongoe
p.1 #9 · Intermittent Rear Control Wheel on 1D
Please let us know how it works out.
Jan 04, 2012 at 06:59 PM
