Archive 2011 · 7D Shutter Problem
tdaportland
p.1 #1 · 7D Shutter Problem
Hi, I just thought I would see if anyone has come across this issue and has a fix, short if sending it into Canon. When I turn on my 7D the shutter activates. I shoot only in manuel mode, but it happens in every setting. When I set it in burst mode, the shutter just keeps activating untill I turn the camera off. I have removed all the batteries including the clock battery, put in all new batteries, changed the lens but nothing helps. I use a canon battery grip just as added information. Both buttons seem to be fine, they are not stuck. It is very perplexing because the camera was working fine when I put it away after my last tournament. I simply brought it home and it started doing this. Ant suggestions?
Dec 30, 2011 at 08:53 PM
rhyx
p.1 #2 · 7D Shutter Problem
Does this happen with the grip disconnected?
It sounds like the camera thinks one of the shutter buttons is depressed.
Dec 30, 2011 at 09:16 PM
tdaportland
p.1 #3 · 7D Shutter Problem
It acts that way but the buttons are free and still have the two stage depression. I have tried turning the battery grip off also to no avail.
Dec 30, 2011 at 09:25 PM
Andrew J
p.1 #4 · 7D Shutter Problem
Take the grip off and try another CF card.
It sounds a little like mirror lockup is enabled so just check that (under custom functions) while you are at it.
Dec 30, 2011 at 09:30 PM
rhyx
p.1 #5 · 7D Shutter Problem
Try taking the grip completely off...not just flipping the switch. Just because the buttons still depress doesn't mean the inside sensor thing isn't stuck.
Try a factory reset on the camera also.
Dec 30, 2011 at 09:46 PM
tdaportland
p.1 #6 · 7D Shutter Problem
Thanks guys, It's begining to look like a trip to Canon for my 7D. I have tried removing the battery grip and tried several other CF cards. I have reset the camera to basic settings also to no avail.
Dec 30, 2011 at 09:52 PM
John_T
p.1 #7 · 7D Shutter Problem
The On/Off switch on the grip only activates/deactivates the grip buttons, but does not turn the grip or anything else on or off.
Sounds like you've got a short in the shutter button or an electronic component failure inside the camera. Trip to Canon is likely the only solution.
Dec 30, 2011 at 11:04 PM
greggn
p.1 #8 · 7D Shutter Problem
I don't mean to sound harsh but even if no one else is experiencing this issue is it something that you're willing to live with ?
I mean, why even ask ... just send it back for repair.
Dec 31, 2011 at 12:07 AM
EB-1
p.1 #9 · 7D Shutter Problem
That sounds like a bad shutter, a la the 20D.
Dec 31, 2011 at 12:11 AM
