Archive 2011 · 24mm ts-e II rotation and shift independent ?
pompo
p.1 #1 · 24mm ts-e II rotation and shift independent ?
is the shift on the V2 now completely independent from the rotation of the lens? I seem to remember that was one of the improvements on the newer version of the 24mm ts-e ...
Edited on Dec 29, 2011 at 09:58 PM · View previous versions
Dec 29, 2011 at 07:20 PM
Admin
p.1 #2 · 24mm ts-e II rotation and shift independent ?
Moved to the Canon board...
and to answer your question, YES.
Dec 29, 2011 at 09:54 PM
pompo
p.1 #3 · 24mm ts-e II rotation and shift independent ?
thanks!!..I meant to delete the post once I realized it was in the wrong place but couldn't...Anyway great news for da 24! Happy New year!!!
Dec 29, 2011 at 09:57 PM
p.1 #4 · 24mm ts-e II rotation and shift independent ?
IOW, yes indeedy!
pompo
p.1 #5 · 24mm ts-e II rotation and shift independent ?
then it might be the time to BUY a TS-E!!!
Dec 29, 2011 at 10:00 PM
EB-1
p.1 #6 · 24mm ts-e II rotation and shift independent ?
Yes, it moves around to quite a number of positions, but is not as flexible as a view camera. The 24 TSE II is an exceptionally good lens all around and well built.
Dec 30, 2011 at 04:24 AM
saneproduction
p.1 #7 · 24mm ts-e II rotation and shift independent ?
The 17 is the same as far as that goes! You can also use the TC 1.4 with the TS-E lenses (unofficialy) though they report the aperture wrong (eg. f4 is really. 5.6, 5.6 is really f8 etc.). The 17 does a good job of playing 24 at f11!
Dec 30, 2011 at 04:32 AM
