  Canon EF 24-70 f/4L IS for $1,299
Archive 2011 · 70-200 2.8L version II noise
teebat
p.1 #1 · 70-200 2.8L version II noise
It's not a problem, but it is curious. I have noticed that on my 70-200 2.8L version II the IS is much louder on my 1ds II than it is on my 1d IV, using the same camera settings ( both cameras set to manual with identical settings) . It's not noticeable on the orginal 70-200 2.8L .
I thought the lens was having problems until I moved it from the 1ds II to the 1d IV, strange that it's so much quieter.
Dec 28, 2011 at 07:59 PM
eskimochaos
p.1 #2 · 70-200 2.8L version II noise
It didn't have IS.
Dec 28, 2011 at 08:32 PM
p.1 #3 · 70-200 2.8L version II noise
It sounds the same on my 1DsIII, 1DIV and 5D. Maybe your 1DsII has a resonating cavity inside - where the film should go...
Dec 28, 2011 at 08:34 PM
PetKal
p.1 #4 · 70-200 2.8L version II noise
I have a couple of theories as to the cause of the difference in the IS noise you have observed.
In order to complete my analysis, I'd like you to perform an additional test please.
Listen to the lens EMD operating on 1DsMkII and 1DMkIV. Note and report on any difference in noise.
Dec 28, 2011 at 08:39 PM
RobertLynn
p.1 #5 · 70-200 2.8L version II noise
I can't even hear the is in my version two, where I could clearly hear it in my version one, if there were no other noises. My 55-250is makes some weak sounds.
Dec 28, 2011 at 08:46 PM
gvg45
p.1 #6 · 70-200 2.8L version II noise
+1. The IS in my MKII is silent. I have to listen carefully to hear it disengage just to make sure it's working.
Dec 28, 2011 at 09:04 PM
p.1 #7 · 70-200 2.8L version II noise
PetKal wrote:
I have a couple of theories as to the cause of the difference in the IS noise you have observed...
It's always better to publish your theories before the supporting data become available...
Dec 28, 2011 at 09:50 PM
runamuck
p.1 #8 · 70-200 2.8L version II noise
You have to do this the right way, as per Dick Cheney. You have an answer. You just have to force the facts to fit that answer. He must be right, because he managed to get away with shooting a guy in the face with a shotgun.
Dec 28, 2011 at 11:43 PM
ytsaelee
p.1 #9 · 70-200 2.8L version II noise
The IS on my MKI is soft and the MKII is loud. must be different copies different sounds.
Dec 28, 2011 at 11:45 PM
big country
p.1 #10 · 70-200 2.8L version II noise
one of mine is pretty noisy. i sent it into canon and they said it was fine.
Dec 29, 2011 at 12:25 AM
Jim Victory
p.1 #11 · 70-200 2.8L version II noise
I can't hear my wife must less my 70-200 f/2.8L IS II.
Dec 29, 2011 at 12:30 AM
EB-1
p.1 #12 · 70-200 2.8L version II noise
I hear the IS on both lenses. It is a bit more quite/smooth on the version II lens.
Two of the 70-200/2.8 non-IS lenses I used made a soft, very high frequency noise, perhaps from the AF.
Dec 29, 2011 at 05:42 AM
teebat
p.1 #13 · 70-200 2.8L version II noise
I mean the 70-200 2.8L IS
eskimochaos wrote:
It didn't have IS.
Dec 30, 2011 at 09:19 PM
teebat
p.1 #14 · 70-200 2.8L version II noise
Will do and get back to you,
Dec 30, 2011 at 09:20 PM
AChilders
p.1 #15 · 70-200 2.8L version II noise
Jan 01, 2012 at 12:17 AM
jerrykur
p.1 #16 · 70-200 2.8L version II noise
Are the modes the same? Perhaps one camera is in one shot and the other in servo.
Jan 01, 2012 at 03:45 PM
jerrykur
p.1 #17 · 70-200 2.8L version II noise
You are going to pay for that one.
Jan 01, 2012 at 03:46 PM
RobertLynn
p.1 #18 · 70-200 2.8L version II noise
How much is that upgrade?
Jan 01, 2012 at 04:02 PM
