       2       3              6       7       end
Archive 2011 · Time to ask the pros for advice ...
dortizphoto
p.1 #1 · Time to ask the pros for advice ...
Greetings everyone!
I just ordered a Canon 50mm f/1.4 prime for my Canon 1Dmk3 which took some getting over since I felt guilty about it. Well, now I'm faced with another dilemma ... which filter to put on that lens. I plan to keep this lens on the body 99.5% of the time and I want to project it, but at the same time don't want something in front of it that will jeopardize image quality.
That being said, I believe I thought too quickly and was sold on the "Hoya" product so I ordered a 58mm filter. The following one to be exact ...
Hoya 58mm Ultraviolet UV Haze HD (High Density) Digital Glass Filter: $36.00
http://www.bhphotovideo.com/c/product/574271-REG/Hoya_XHD58UV_58mm_Ultraviolet_UV_Haze.html
Now I'm wondering if I made a mistake, and maybe should have ordered this product instead:
Heliopan 58mm UV (Haze) SH-PMC (Super Multi-Coated) Filter: $78.99
http://www.bhphotovideo.com/c/product/232469-REG/Heliopan_705811_58mm_UV_Haze_SH_PMC.html
Any help will be humbly appreciated.
Thanks,
Dave
Dec 28, 2011 at 05:37 PM
stanj
p.1 #2 · Time to ask the pros for advice ...
No filter. Putting a cheap filter on it will jeopardize the quality, and putting a pricy protective filter on such a cheap lens is not very productive.
Dec 28, 2011 at 05:40 PM
dortizphoto
p.1 #3 · Time to ask the pros for advice ...
Well, I'd like some protection on the lens. I did order the hood for it, but felt adding a filter would help with protection, haze, color, etc. Maybe I'm wrong?
Thanks,
Dave
Dec 28, 2011 at 05:42 PM
artsupreme
p.1 #4 · Time to ask the pros for advice ...
The best thing you can do for this lens is keep the hood installed at all times. If you don't you'll be sending it in for repair. No filter required.
Dec 28, 2011 at 05:43 PM
dortizphoto
p.1 #5 · Time to ask the pros for advice ...
OK, so I should send that Hoya back then since I paid for it and will arrive Friday. What about for my other two canon lenses. 24-70 f/2.8L and 70-200 f/2.8L ... should I invest in the higher end filter for those?
Dec 28, 2011 at 05:45 PM
RogerC11
p.1 #6 · Time to ask the pros for advice ...
I keep a B+W filter on my 24-105 and 70-200.
Dec 28, 2011 at 05:51 PM
Sp12
p.1 #7 · Time to ask the pros for advice ...
What's the point of an expensive filter for a cheap lens?
Dec 28, 2011 at 05:52 PM
dortizphoto
p.1 #8 · Time to ask the pros for advice ...
Not to, shall I say ... "further" degrade the optics - I suppose.
Dec 28, 2011 at 05:53 PM
p.1 #9 · Time to ask the pros for advice ...
I only use protective UV or clear filters on the rare occassions that I shoot in a hostile environment with blowing sand, salt water spray, and similar challenges. When I do use one, it's a B+W MRC filter. I have a few in 77mm diameter, and singles in other sizes, which covers my needs.
Every year or two I do a comparison of UV filter vs. no filter in very bright conditions, and I've never seen the UV filter produce better images. In many conditions, a filter will add a touch of flare, that slightly reduces contrast, which is counter-productive for sharp images.
You'll find many previous posts on these issues. Try this for starters, http://www.fredmiranda.com/forum/topic/745528
Edited on Dec 28, 2011 at 06:01 PM · View previous versions
Dec 28, 2011 at 05:55 PM
dortizphoto
p.1 #10 · Time to ask the pros for advice ...
Dear Lord, that first image makes me DIZZY just looking at it. Sheeeeeesh. :-)
Dec 28, 2011 at 05:58 PM
gdsf2
p.1 #11 · Time to ask the pros for advice ...
Hi,
Why would you want to keep the 50mm f/4 on 99.5% of the time when you own two other great lenses? Do you really want to limit yourself to one focal lenght?
On the filter question - I would only use one in nasty situations. Otherwise the hood provides plenty of protection.
Jerry
Dec 28, 2011 at 06:04 PM
dortizphoto
p.1 #12 · Time to ask the pros for advice ...
Hello Jerry - I find the 24-70 is a beast to walk around with. Tack on the 1Dmk3 and I'm walking around with a brick. The result is I leave the camera in the bag more than I should. Yes, the 50mm I just ordered is a cheap lens, but it's also small, light and will force me to not only use the camera more, but experiment and become proficient with DOF calculations which has always been a challenge for me.
Thanks,
Dave
Dec 28, 2011 at 06:09 PM
eskimochaos
p.1 #13 · Time to ask the pros for advice ...
No filter unless, as mentioned, environmental conditions warrant it. 50mm 1.4 isn't that special anyways.
Dec 28, 2011 at 06:50 PM
svassh
p.1 #14 · Time to ask the pros for advice ...
Hi Dave,
I recently purchased the same lens and I have a very cheap filter on it just some no name. On my 'expensive' L lenses I spent more for good Canon and Hoya clear filters. I know many have strong opinions on this board and others regarding the need for filters. I use them to provide some level of protection from scratches or dirt. I thinks its more peace of mind than anything else as I am doubtful they would provide any significant impact protection. IMHO unless you are blowing up images or doing no post processing what so ever it is unlikely you would see a significant degradation in image quality. At least not enough for my old eyes to notice. Do whatever makes you feel comfortable I like my 50 1.4 and think its a great alternate walk around lens for my 7D and especially my 1D Mk IIn. Good luck with the new lens and I hope it allows you to get that camera out of the bag more often.
Scott
Dec 28, 2011 at 06:52 PM
cputeq
p.1 #15 · Time to ask the pros for advice ...
I'm not really going to go on a crusade for or against UV filters, but I don't use them on any of my gear unless I know I'm shooting in conditions where lots of water or sand is definitely going to hit the lens.
I guess some people like them to help with dust intake on certain lenses, but dust has never bothered me nor have I had it affect a photo.
CPOL, sure, GND, sure, but UV - meh. I just use the lens hood.
Dec 28, 2011 at 07:11 PM
stanj
p.1 #16 · Time to ask the pros for advice ...
Next time you have a few spare minutes, take a picture of your house at night. Or just the street lamp, in such a way that it's off center. You'll end up with two - one exactly opposite, upside down. That's what the filter did.
Dec 28, 2011 at 07:15 PM
Tom Dix
p.1 #17 · Time to ask the pros for advice ...
This is one issue that I feel very strongly about. I never use uv filters. Total waste of money, and as Stan points out major issues can occur in certain situations.
The 50 1.4 is a fine optic. Do not mask it. Just my .02
Dec 28, 2011 at 07:25 PM
John_T
p.1 #18 · Time to ask the pros for advice ...
...remember the thread a few years ago where the OP was convinced he had photographed a green ghost? It took about a hundred pages before somebody asked the OP if he had a "protective filter" on the lens, and another 500 pages before the OP was convinced to remove the filter.
Lens cap and hood are all you need to ward off ghosts...
Dec 28, 2011 at 07:30 PM
Psychic1
p.1 #19 · Time to ask the pros for advice ...
John_T, are to trying to put me out of business
Actually, the 50-1.4 would not be my choise as a 95% of the time lens, especially in Florida where it rains a few times a day.
Filter or not, the 50-1.4 is one of the least protected lenses in the Canon lineup.
With the 1DIII, 24-70L and 70-200L I would choose the 24L II or 50L.
I use B&W and I enjoy shooting in all types of weather.
Dec 28, 2011 at 07:38 PM
RobertLynn
p.1 #20 · Time to ask the pros for advice ...
This.
I used to say that while I understand my filter may in theory change image quality, I've never seen it in practice.
Then I dd some long exposure night photography. Changed my views in one ruined outting.
Look at the front of your filter. Glass is flat. Look at your lens, more than likely it's not. Do you think the filter was made to the same exacting specifications that a high precision lens element is? I think not.
Don't put bad money on a good lens. Besides, what are you protecting it from? If it is rain/snow/blood of the non-believers, the lens isn't weather sealed.
There's in my mind, no reason other than actual protection from real environmental conditions to use a filter. Creative filters not withstanding.
Dec 28, 2011 at 08:43 PM
       2       3              6       7       end
       2       3              6       7       end
