Archive 2011 · Clean contacts?
tanglefoot47
p.1 #1 · Clean contacts?
Besides spit and a paper towel what is the best method to cleaning the camera contacts?
Mikey
Dec 24, 2011 at 10:19 PM
roboticspro
p.1 #2 · Clean contacts?
Hey Mike,
I have used CRC electrical contact cleaner for years on electrical assemblies; you can find it at Home Depot and Lowes in the electrical supplies section. Another "solution" is Everclear, available from your local gun & beverage store, at least the ones' I know in Fallon, Nevada... .
Regards,
Edd
Dec 24, 2011 at 10:33 PM
jaybird555
p.1 #3 · Clean contacts?
Pencil eraser.
Dec 24, 2011 at 10:39 PM
tanglefoot47
p.1 #4 · Clean contacts?
jaybird555 wrote:
Pencil eraser.
Isn't an eraser a little abrasive? Think I have heard not to use it on contacts.
Dec 24, 2011 at 10:49 PM
tanglefoot47
p.1 #5 · Clean contacts?
roboticspro wrote:
Hey Mike,
Regards,
Edd
Good I will check this out I work next to the HD
Dec 24, 2011 at 10:50 PM
Ben Horne
p.1 #6 · Clean contacts?
You could always try a Contact Cleaner
http://www.bhphotovideo.com/c/product/163356-REG/Hama_HA_5629_Contact_Cleaner.html
Dec 24, 2011 at 11:15 PM
Imagemaster
p.1 #7 · Clean contacts?
Q-tip and alcohol.
Dec 25, 2011 at 12:50 AM
tanglefoot47
p.1 #8 · Clean contacts?
This is interesting for sure but I am going to try the Qtip Alcohol method and see what happens
Dec 26, 2011 at 06:36 AM
BrianO
p.1 #9 · Clean contacts?
jaybird555 wrote: Pencil eraser.
tanglefoot47 wrote: Isn't an eraser a little abrasive? Think I have heard not to use it on contacts.
You probably heard it from a contact cleaner salesman.
Seriously, I've been using the eraser end of a pencil for battery and lens contacts for years; never had a problem. I just go gently, and I break out the contact cleaner if it's really bad.
Dec 26, 2011 at 09:23 AM
chas
p.1 #10 · Clean contacts?
From the school of "If it ain't broke....", do you clean your contracts only after you have had an error occur, or just as a routine maintenance process? Having owned Canon gear for over 8 years, I have never cleaned contacts.
Dec 26, 2011 at 02:12 PM
Ben Horne
p.1 #11 · Clean contacts?
If you guys are cleaning the contacts just for the sake of cleaning the contacts... it really isn't necessary. I would only clean them if you are having a problem such as a corroded battery in a flash, or something along those lines. I think more photographers damage their equipment by overzealous cleaning than other common causes.
Dec 26, 2011 at 04:27 PM
BrianO
p.1 #12 · Clean contacts?
chas wrote: From the school of "If it ain't broke....", do you clean your contracts only after you have had an error occur, or just as a routine maintenance process? Having owned Canon gear for over 8 years, I have never cleaned contacts.
Ben Horne wrote: If you guys are cleaning the contacts just for the sake of cleaning the contacts... it really isn't necessary. I would only clean them if you are having a problem such as a corroded battery in a flash, or something along those lines. I think more photographers damage their equipment by overzealous cleaning than other common causes.
"If it ain't broke don't fix it" works for some folk, "An ounce of prevention is worth a pound of cure" works for others.
I look at my contacts every time I change a lens or a battery. If I see any black or green where I should see only silver or gold, I clean it; if I don't, I don't.
Dec 26, 2011 at 06:47 PM
scalesusa
p.1 #13 · Clean contacts?
The contacts are gold plated, and do not ozidize. The "wiping" action as you twist a lens to install it will almost always wipe away any light dirt or oil.
Unless you are in a very dirty / oily environment, cleaning the contacts only serves to wear off the gold plating, and then you really will need to clean corrosion away.
If you must clean them, use a soft non-abrasive cloth and alcohol or a non-abrasive contact cleaner.
I've had dozens of lenses and many camera bodies over the past 15 years and never needed to clean the contacts.
Dec 26, 2011 at 06:56 PM
