FM Actions & Plugins support
Workflow Guidelines
Archive 2011 · UPC code for Epson 3880?
Norman my love
p.1 #1 · UPC code for Epson 3880?
Does anyone know where the UPC Code is for the Epson 3880? I can't see any barcode with numbers or anything like the rebate info says should be on the box.
Dec 24, 2011 at 06:19 AM
howardm4
p.1 #2 · UPC code for Epson 3880?
on my 3800, there was a white stick-on label w/ the UPC, unit's serial number and some other info. I'd kinda doubt the UPC would be hard-printed on the corrugated cardboard box itself.
Dec 24, 2011 at 01:56 PM
Norman my love
p.1 #3 · UPC code for Epson 3880?
Thanks Howard,
In the past on some items, it has actually been on the colored box and you had to cut a rectangle out of the box.
I don't see it and I am very unhappy with B&H. Normally they have ample packing material between the inner box and the outer box, but I guess because this is so big, the outer box has only 1/4 space all around and had a split in it when it arrived. The Epson box got a couple crushed corners and the styrofoam that holds the printer cracked, making me concerned that their was some trauma to the printer.
Dec 24, 2011 at 03:48 PM
JimboCin
p.1 #4 · UPC code for Epson 3880?
Send it back if you are at all concerned.
B&H will have no problem with you returning it.
Edited on Dec 27, 2011 at 12:45 AM · View previous versions
Dec 25, 2011 at 12:12 PM
Photon
p.1 #5 · UPC code for Epson 3880?
I'll be watching for this, as I expect delivery of a 3880 (from Adorama) Tuesday. The $300 rebate is no trifle!
Dec 25, 2011 at 06:27 PM
