Archive 2011 · Full-time manual override during video
ctrlcctrlv
p.1 #1 · p.1 #1 · Full-time manual override during video
Does anyone know if the full-time manual override on lenses will also work while shooting video? More specifically, I know you CAN turn the focus ring during video while it is set to AF, but is it "bad" for the lens/focus system?
Thanks again.
Dec 22, 2011 at 09:31 PM
rslhc
p.1 #2 · p.1 #2 · Full-time manual override during video
If your lens has Ring USM that allows for Full Time Manual override while the lens is set in AF, then you will not need to take it out of AF (via the switch) to focus during video. Full time means full time. It will function as if it was in MF unless you trigger AF during shooting.
What lens(es) are you shooting with?
Dec 22, 2011 at 10:21 PM
ctrlcctrlv
p.1 #3 · p.1 #3 · Full-time manual override during video
The 24L II on the 7D
Dec 22, 2011 at 10:27 PM
scalesusa
p.1 #4 · p.1 #4 · Full-time manual override during video
You can just focus your 24mm L without switching to manual focus. There is a slip clutch in the lens. It will not cause any damage to use it this way.
Dec 23, 2011 at 04:34 AM
Dave_EP
p.1 #5 · p.1 #5 · Full-time manual override during video
We never take our lenses out of AF during video and DO manually focus for video much of the time.
The AF will only kick in if you press and hold the AF button on the camera and the rest of the time the AF is disengaged (on full time MF lenses such as the 24L, 24-70L etc).
Dec 23, 2011 at 05:15 AM
