Archive 2011 · Different spec US and Europe Cpture nx2
ghamden
p.1 #1 · Different spec US and Europe Cpture nx2
Europian Spec sheet
"- Compatible with both 32 and 64-bit versions of Windows 7 and Vista.
This software operates as a native 64-bit application under the 64-bit versions of Windows 7 and Windows Vista."
US Version Spec sheet
•* - 32- and 64-bit versions are supported. However, under 64-bit versions, the software operates as a 32-bit application.
i installed the europe version 64 bit now that the US version is up i was going to install but.....
i am wondering what gives??
Dec 22, 2011 at 07:30 PM
ghamden
p.1 #2 · Different spec US and Europe Cpture nx2
after more reading i found more specs on us
•This software now operates as a native 64-bit application under the 64-bit versions of Windows 7 and Windows Vista
so looks good to go
Dec 22, 2011 at 07:37 PM
Gregg B.
p.1 #3 · Different spec US and Europe Cpture nx2
You should be able to see what mode is the application running in.
If you have a 64-bit Windows 7 or Vista installed then all applications in the Windows Task Manager that are NOT running natively (in 64 bit mode) are marked in the Processes tab as *32. So for example, I have firefox.exe *32 listed there, and obviously it means that the firefox is running in a 32 bit mode, therefore it's a 32bit application, but winword.exe isn't, and it doesn't have the "*32" next to its name.
Did I make this clear?
Now, go and check your Task Manager and run both European and US version to see if there are any differences, then let us know.
Thanks
Greg
Dec 22, 2011 at 07:44 PM
ghamden
p.1 #4 · Different spec US and Europe Cpture nx2
Just Installed US version all is good runs naitive 64 bit
Dec 22, 2011 at 07:55 PM
ghamden
p.1 #5 · Different spec US and Europe Cpture nx2
also note Tranfer is still 32 bit does not default to the 64 bit version you have to go into transfer preferences and direct it to the proper location of cnx2 64 bit or files will just be opened in explorer
Dec 22, 2011 at 08:00 PM
