  Canon EF 24-70 f/4L IS for $1,299
       2       3       end
Archive 2011 · Glasses while shooting & best strap...
gheller
p.1 #1 · Glasses while shooting & best strap...
Hi all
I want to know what you guys do out in the field on 2 issues (while shooting with your Canon gear )
(1) what do you guys do with your glasses (regular or sunglasses) when you are shooting? I find that I throw them in my sling bag, but not crazy about that option.
(2) besides Black Rapid (which I really like), any other really innovative straps that are different in any way that you can recommend?
Thanks
greg
Dec 08, 2011 at 08:34 PM
omarlyn
p.1 #2 · Glasses while shooting & best strap...
gheller wrote:
I want to know what you guys do out in the field ...(while shooting with your Canon gear )
greg
Scratch the hell out of them by putting my glasses in my shirt pocket and forgetting about them until I bend down and they fall out!
Omar
Dec 08, 2011 at 08:41 PM
15Bit
p.1 #3 · Glasses while shooting & best strap...
1. Lose them, more often than not.
2. I have a hand strap from Camdapter.
Dec 08, 2011 at 09:17 PM
robstein
p.1 #4 · Glasses while shooting & best strap...
- Glasses - No idea sorry.
- I use the camdaptor hand strap as well and with my RRS plate on the bottom I have lugs in 4 corners... so handstrap takes 2 on right and a removable neck strap takes the 2 left ones. I have lost 2 removable straps since they are off most of the time unless I am out and about (they don't let me out much so that's less common ).
I tried to like slings... but I cannot stand the camera on my right side (leftie) or the strap on my right shoulder when I hang it backwards to drop to the left side :shrug:
Dec 08, 2011 at 10:26 PM
David Baldwin
p.1 #5 · Glasses while shooting & best strap...
"what do you guys do with your glasses (regular or sunglasses) when you are shooting?"
Keep them on! I am dramatically shortsighted and need to wear them all the time. Have absolutely no problem shooting with the 7D and 5D2.
Dec 08, 2011 at 11:31 PM
Ernie Aubert
p.1 #6 · Glasses while shooting & best strap...
I put my glasses in a pocket. I use this rather than a neck strap:
http://www.bhphotovideo.com/c/product/631170-REG/Trekking_TS12312_Safari_Strap.html
Dec 08, 2011 at 11:51 PM
RobertLynn
p.1 #7 · Glasses while shooting & best strap...
gheller wrote:
Hi all
Thanks
greg
Get contacts.
Dec 09, 2011 at 12:25 AM
erikburd
p.1 #8 · Glasses while shooting & best strap...
I wear my glasses. No problems on my end.
Dec 09, 2011 at 12:27 AM
gdanmitchell
p.1 #9 · Glasses while shooting & best strap...
gheller wrote:
Hi all
I leave 'em on. For me, it is too much trouble to take glasses off and put them back on every time I'm making a shot. I do sometimes slide them down on my nose when using live view - hard to focus on the close stuff sometimes!
I often use clip on sunglasses. Those come off. The added thickness interferes with seeing through the viewfinder, and they have a tendency to come loose while shooting. Most of the time when I'm in the field I wear shirts with chest pocket, so the clip ons go there.
Dec 09, 2011 at 02:48 AM
PilotDan
p.1 #10 · Glasses while shooting & best strap...
Keep them on...otherwise I'd think every shot is totally out of focus and I'd trip on stuff in between shots.
Dec 09, 2011 at 03:00 AM
Gunzorro
p.1 #11 · Glasses while shooting & best strap...
Op Tech Pro Strap distributes weight best that I've found. I like it on all my cameras which are either 1D-type or 5D/60D with grip.
Dec 09, 2011 at 03:17 AM
misterbill7718
p.1 #12 · Glasses while shooting & best strap...
I always wear my eye-glasses when I shoot. I'd probably trip and break my camera/lens if I didn't. No problems shooting with them on. I don't ever wear sunglasses when I shoot, even if it is really bright, I just wear a hat with a decent brim.
Dec 09, 2011 at 04:07 AM
gheller
p.1 #13 · Glasses while shooting & best strap...
fantastic suggestions and input... keep them coming
greg
Dec 09, 2011 at 05:10 AM
lukeb
p.1 #14 · Glasses while shooting & best strap...
+1 on D700's
Dec 09, 2011 at 05:17 AM
eskimochaos
p.1 #15 · Glasses while shooting & best strap...
A glasses case perhaps?
Dec 09, 2011 at 05:19 AM
Photon
p.1 #16 · Glasses while shooting & best strap...
I wear my glasses full-time, so they don't go anywhere when I shoot.
I like the Up-Strap. I wear it on one shoulder instead of around my neck, and it is so secure that I never worry it might slip off. Sometimes I prefer to work without any strap on the camera. Other times I'm using two bodies, and for that I think I'm going to try Ernie's suggestion of the Trekking Safari Strap.
Dec 09, 2011 at 05:40 AM
garyroach
p.1 #17 · Glasses while shooting & best strap...
I'm in the habit of sliding my glasses up on my forehead when looking through the viewfinder. I can see clearly by adjusting the diopter in the viewfinder. Works for me!
The only straps I use are Canon hand straps on the camera bodies.
Edited on Dec 11, 2011 at 04:58 PM · View previous versions
Dec 09, 2011 at 05:42 AM
Gunzorro
p.1 #18 · Glasses while shooting & best strap...
For glasses (reading glasses), I simply put them in a shirt pocket when not in use.
Dec 09, 2011 at 05:50 AM
Jeff Donald
p.1 #19 · Glasses while shooting & best strap...
The best sling I've found is the Sun Snipper[url=]http://www.sun-sniper.com/en.html[/url]. It has several unique features:
1. Stainless Steel bearing attachment point
2. integrated shock absorber
3. integrated steel cable could help prevent theft
Disclaimer, I don't work for the mfg., any distributor or reseller, just a happy owner.
Dec 09, 2011 at 06:17 AM
Greggbhill
p.1 #20 · Glasses while shooting & best strap...
+1
Dec 09, 2011 at 06:27 AM
       2       3       end
       2       3       end
