Archive 2011 · 35mm 1.8 on fx?
OO7MIKE
p.1 #1 · 35mm 1.8 on fx?
I've heard that some photographers are using the 35mm f1.8 on FX and are pretty happy with it but I haven't been able to find any decent photographs taken with it. Most are just snapshots. I'd like to see something more impressive with it.
the only thing I'm worried about is having soft corners and lots of vignette. I don't mind a little bit of vignette or a softness just not a lot. Its either this lens or the 35 f2. I like the bokeh and sharpness much better on the 35mm f1.8. BTW I wont be using this lens in crop mode. FX only!
I look forward to seeing some examples! Thanks!
Dec 01, 2011 at 07:25 PM
jhinkey
p.1 #2 · 35mm 1.8 on fx?
Did you look here:
http://www.flickr.com/photos/canderson/sets/72157622462281022/
There are lots of snapshots per se, but they seem to give a sense of the light falloff and sharpness.
John
Dec 01, 2011 at 07:33 PM
jhinkey
p.1 #3 · 35mm 1.8 on fx?
Also give this thread a try:
http://www.fredmiranda.com/forum/topic/916168
John
Dec 01, 2011 at 07:35 PM
lxdesign
p.1 #4 · 35mm 1.8 on fx?
its a different look indeed .... if you like having a permanent vignette.... almost like shooting with a Holga
Dec 01, 2011 at 09:02 PM
rsolti13
p.1 #5 · 35mm 1.8 on fx?
Overall, I like what this lens offers on the D700 for under $200. I wouldn't pay much more than that for use on FX. I had both the 35 f/2 and the 35 f/1.8 and chose this one. It is FAR sharper dead center and to about 3/4 of the frame out. Past that, the lens isn't built for and it drops off significantly. Heavy vignetting and soft corners. The bokeh is so so in my opinion and downright dizzying in some situations (see below). However, don't let that steer you away, I love the vignetting and what I mainly use it for (people) it doesn't bother me at all. Images really pop with this lens. If you want to use it for landscapes, forget about it. I wouldn't dare touch this lens.
Anyways....here are some recent on a D700, all either wide open or close to
Dec 01, 2011 at 09:03 PM
AndreasE
p.1 #6 · 35mm 1.8 on fx?
The pattern of vignetting depends on the f-stop. Shot wide open and using RAW, a significant part of vignetting can be corrected (with noise increase in the corners). Correction does not help, when stopped down.
AFS 35mm @ f1.8, D3s, full image only resized
This is the level of vignetting with vignetting correction set in CNX2 to the max value
AFS 35mm @f11
CNX2 vignetting-correction set to max
regards,
Andy
Dec 01, 2011 at 11:46 PM
cputeq
p.1 #7 · 35mm 1.8 on fx?
Focus distance plays a part in how it vignettes iirc. Frankly for fx i would use a f/2 because there are a few instances where the 1.8 just vignettes too much even for me. Im not sure how sharp the f/2 is, though so if primary concern is tack sharp, the 1.8 is a strong argument.
Dec 02, 2011 at 12:45 AM
huddy
p.1 #8 · 35mm 1.8 on fx?
Typically, those who show great results are using them for night/event photography where the falloff doesn't negatively effect the shots. I'd just get a 35/2 AF-D or 35/2 AI-S.
Dec 02, 2011 at 03:31 AM
jhinkey
p.1 #9 · 35mm 1.8 on fx?
I think the images of his daughter look great - maybe because I'm used to the light fall-off of my 50/1.2 wide open. I've always been interested in using a 35/1.8G on my D700 for close up candid shots and these look pretty good - Alan's 28/2 AI is also a great lens for that too, but it won't vignette quite as much at any focal distance .
John
Dec 02, 2011 at 04:20 AM
EB-1
p.1 #10 · 35mm 1.8 on fx?
The bokeh on some of those is making me dizzy.
Dec 02, 2011 at 04:23 AM
doolbnroht
p.1 #11 · 35mm 1.8 on fx?
I haven't posted much here but decided to weigh in on this. On my D700, this is my favorite fun lens. It's small and I like the way it shoots.
It's AF is fast and seems to be pretty right on all the time.
(sorry for all the kid pics)
Untitled-2 by a.hoglen, on Flickr
Untitled-10 by a.hoglen, on Flickr
inbox by a.hoglen, on Flickr
dinnerwithmimi1 by a.hoglen, on Flickr
Dec 02, 2011 at 08:13 AM
DennisC
p.1 #12 · 35mm 1.8 on fx?
For people pics, about how far away from your subject can you be before things start falling apart?
Nice samples!
Dec 02, 2011 at 03:58 PM
rsolti13
p.1 #13 · 35mm 1.8 on fx?
Nice samples!
It depends on distance and aperture used. The closer you are and the wider aperture you use the less vignetting you see. If you get really close up you won't see any at all. As discussed, even wide open at about 10m out you will see vignetting on FX. Stopped down to lets say f/5.6 you will see vignetting close up and severe at distance. It all depends. See my shots above - about 7-10m out for most and you see slight vignetting which for the most part can be cleaned up in post if I wanted. I don't want to though, I like the look
close up with wide aperture (f/2) - NO vignetting
another....f/2.2 with no vignetting
Dec 02, 2011 at 04:47 PM
lxdesign
p.1 #14 · 35mm 1.8 on fx?
I decided to chime in .... I went shooting this past Sunday, and decided to try the 35mm f/1.8 on my D700. Here are some shots:
David At The Molson Mill by lxdesign, on Flickr
Fudge Mill Plate Grinder by lxdesign, on Flickr
Maureen & Chris by lxdesign, on Flickr
Check them out and see the rest on my flickr
Dec 07, 2011 at 02:45 AM
