Archive 2011 · Nikon Flashes and Voltage Issues
Pbmax
p.1 #1 · Nikon Flashes and Voltage Issues
Are the older Nikon flashes (sb25 for example) ok to use with a D80? I just want to make sure before buying a older flash that there isn't a issue with voltage and blowing out the camera. Such as using a Vivitar 283 high voltage unit on the hot shoe of a digital camera. THANKS!
Nov 28, 2011 at 06:38 PM
runamuck
p.1 #2 · Nikon Flashes and Voltage Issues
speedlights.net says it has a trigger voltage of 4 volts, so it is okay.
Nov 29, 2011 at 02:36 AM
Two23
p.1 #3 · Nikon Flashes and Voltage Issues
I have used both SB-28 and SB-25 on D80 & D300. Set the flash to "A" mode (auto,) not TTL.
Kent in SD
Nov 29, 2011 at 02:38 AM
EB-1
p.1 #4 · Nikon Flashes and Voltage Issues
Any Nikon flash of the past 25 years or so that has an A mode should work if you can live with that mode.
Nov 29, 2011 at 02:56 AM
Pbmax
p.1 #5 · Nikon Flashes and Voltage Issues
I am happy with "A" mode... not a big fan of the TTL modes... THANKS!
Nov 29, 2011 at 05:41 AM
