Archive 2011 · Canon 500D Close Up Lens
bqq100
p.1 #1 · Canon 500D Close Up Lens
Been looking to pick one of these up with a 72mm thread, but don't seem to be in stock except at some places known for the old bait n switch. Anyone know why the shortage?
Nov 22, 2011 at 01:32 AM
Starlightbreakr
p.1 #2 · Canon 500D Close Up Lens
i can safely assume you posted on the wrong forum.
Nov 22, 2011 at 01:34 AM
trenchmonkey
p.1 #3 · Canon 500D Close Up Lens
^ I have a 500D and a 250D and shoot NIKON They're close-up 2 element screw on lenses (filters)
that don't give a rats ass what they're fastened to. His thread is fine here. To answer the OP's query....
they might have infrequent production runs. Look on fleaBay for used or post a WTB on our B&S Forum.
The 72's go for ~$90-$100 and work great on the likes of the 105/135 f2 DC's and the 70-300 VR (with a
72 to 67 step down ring) Good luck
  NIKON D7000    300 mm    f/5.6    1/250 sec    100 ISO    -0.3 EV
Nov 22, 2011 at 01:46 AM
ecidi
p.1 #4 · Canon 500D Close Up Lens
The Canon 250D close up attachment works very well with the Nikon 28mm f2.8 ais lens also:
Nov 22, 2011 at 03:27 AM
EB-1
p.1 #5 · Canon 500D Close Up Lens
I used to use the 77mm on the 80-200/2.8 AF-D. It works fine, but is not really a macro.
Nov 22, 2011 at 03:41 AM
bqq100
p.1 #6 · Canon 500D Close Up Lens
Thanks, I am looking to start dabling in the macro world and wanted to get a taste using this on my 18-200 or 50-150 2.8 before splurging on a real macro lens. Was hoping to add it to my x-mas list but if I have to get it on fleabay i'll probably end up getting myself a little x-max present!
Nov 22, 2011 at 04:56 AM
String
p.1 #7 · Canon 500D Close Up Lens
I use a 500D on the 70-200 and it works perfectly for flowers; don't consider it a macro lens but an excellent close-up lens. The bonus being that it's small enough to fit in your pocket so no excuse for leaving it at home
Here is one with the 500D on the 70-200:
Nov 22, 2011 at 08:46 PM
oobie
p.1 #8 · Canon 500D Close Up Lens
On Tom Hick's recommendation I picked up a 500D (but got the 77 so it'd fit on my nicer glass). Glad I took his advice. I've been happily using it for the past 5 years or so. It's handy to just stick on the 70-200 during weddings to snag some ring-shots.
Nov 22, 2011 at 08:59 PM
jefflee
p.1 #9 · Canon 500D Close Up Lens
Actually with a 300mm the 500D on exceeds 1:1...Comes very close on a 200mm, by definition its is an attachment that turns your long lens into a macro.
Nov 22, 2011 at 09:02 PM
gugs
p.1 #10 · Canon 500D Close Up Lens
I would recommend the 77mm version, a more standard diameter, and add a step up ring to adapt to other lenses (72mm->77mm in your case). I have used one on a 80-400mm for close-up photography and the results have been convincing.
Guy
Nov 22, 2011 at 09:48 PM
Gary Irwin
p.1 #11 · Canon 500D Close Up Lens
Guy
++1. The 77mm will work on a wider variety of lenses. I expect part of the OP's problem is that he's looking for a non "standard" size of 72mm -- check ebay.
I don't do much in the way of closeups, so the 500D works well enough as a macro for me...
Nov 22, 2011 at 10:36 PM
bqq100
p.1 #12 · Canon 500D Close Up Lens
Hmmmm I have been eyeing the 80-200 2.8D 2 ring.... You guys are pretty convincing for the 77mm version
Nov 23, 2011 at 02:07 AM
Tom Hicks
p.1 #13 · Canon 500D Close Up Lens
With the 77 mm you can use it on any lens and only have to buy it once .
Nov 25, 2011 at 06:58 PM
utildayael
p.1 #14 · Canon 500D Close Up Lens
I owned the 77mm 500D and to be honest, if you do more than very light macro use, it's not worth the money. I have been much better served with my 90mm Tamron macro. Losing infinity focus is a pain the ass.
What you DO get with it is decent photos [its a pretty well made closeup filter] and you can slip that filter into your bag easier than another lens.
If you do a LOT of macro work... honestly... save a few more bucks and buy an actual macro lens.
Nov 25, 2011 at 07:30 PM
jefflee
p.1 #15 · Canon 500D Close Up Lens
I've got a T90 and its a great lens. But for those times when I only have my 80-200 or 300 with me, well the 500D works great. On the AFS f4 300 you get almost 1:1. It's a long term buy if you like working with a 70/80-200 f2.8 or 300mm f4 and you need maco capability. Especially if you are traveling with just one lens.
your working at about 20" with the 80-200 (about 10" from the front of the lens) and I'd certainly put one in my bag if I was using either the zoom or the telephoto.http://www.marketmagic.com/GS/Macro/content/bin/images/large/Macro066.jpg
Nov 26, 2011 at 06:01 AM
HerbChong
p.1 #16 · Canon 500D Close Up Lens
those lenses are too short for the 500D. you will find unworkably close shooting distances. the 250D is a better bet even at the longest end of each lens.
Herb...
Nov 28, 2011 at 06:07 PM
GSteele
p.1 #17 · Canon 500D Close Up Lens
Liar, Liar, Pants on fire!
It won't fit on a lens that uses drop in filters!
Herb makes a good point about the 250 and the lenses listed in his reply.
Nov 30, 2011 at 02:06 PM
Two23
p.1 #18 · Canon 500D Close Up Lens
I have the 500D in 77mm and really like it. It's a very compact macro "lens"--one less big lens to pack when hiking. I use it successfully on Nikon 80-400mm VR (butterflies etc.) and also on 70-200mm f2.8 VR. Great image quality; little bulk. There is also Marumi brand, some of which have more magnification.
Kent in SD
Nov 30, 2011 at 04:18 PM
