Archive 2011 · Polarizing filter for Nikon D7000?
go4java
p.1 #1 · Polarizing filter for Nikon D7000?
Hi,
I've done some research on the "right" polar filter for the D7k (67mm).
Based on the ECONO RANKING further down http://www.lenstip.com/115.4-article-Polarizing_filters_test_Results_and_summary.html, my actual candidate is Marumi DHG Circular P.L.D.
Some other suggestions from your side?
BR
Jun 15, 2011 at 01:24 PM
mMontag
p.1 #2 · Polarizing filter for Nikon D7000?
I'm using a Marumi CPL from recommendations on this forum that sometimes referenced that test - I find the B+W's to be too saturated - the Marumi's seem to be on the "gray" side - I'm still undecided if it is a good polarizer in regard to color and negative effect on the images - I wasn't happy with my last images using the Marumi. They are priced right - since I don't use a polarizer often - cheap is OK for now.
Of the polarizers I've used in the past and was most satisfied with was the Nikon - nice and neutral and polarize very well - I just wish they made an 82mm.
http://www.bhphotovideo.com/c/product/300499-REG/Nikon_2255_67mm_Circular_Polarizer_Glass.html
Jun 15, 2011 at 09:44 PM
go4java
p.1 #3 · Polarizing filter for Nikon D7000?
Thanks. In Germany, the Nikon filter is about EUR 100,-, an interesting alternative could be the HOYA: http://www.amazon.de/Hoya-Polarisationsfilter-Cirk-Pro1-Digital/dp/B000KL5T9G/ref=cm_cr_pr_product_top. BR
Jun 16, 2011 at 07:17 AM
trenchmonkey
p.1 #4 · Polarizing filter for Nikon D7000?
Usually filters are paired with lenses NOT bodys. Guess you're referring to the kit lens re: 67mm
Make sure that whichever one you choose is multi-coated. I have a 67mm LightCraft that I use with my 70-300 VR
and it works great, wasn't an arm and a leg either.
Jun 16, 2011 at 11:09 AM
go4java
p.1 #5 · Polarizing filter for Nikon D7000?
...thanks. Yes, my lens is Nikon kit 16-85. Just checking the "multi-coated" and from this URL (sorry, German) http://www.redcoon.de/B119268-Hoya-Pro1-Digital-Pol-Cirk-67mm_Pol-Filter?refId=basede#databox it looks the right filter. BR
Jun 16, 2011 at 11:17 AM
trenchmonkey
p.1 #6 · Polarizing filter for Nikon D7000?
That one should be fine
Jun 16, 2011 at 11:22 AM
Two23
p.1 #7 · Polarizing filter for Nikon D7000?
I bought the Marumi DHG last summer to replace a Hoya SMC that decided to roll off the edge and into Dettifoss in Iceland, last summer. I'm a polarizer guy and really like the Marumi. I would buy another if this one rolls away into another waterfall.
Kent in SD
Jun 16, 2011 at 01:47 PM
go4java
p.1 #8 · Polarizing filter for Nikon D7000?
Kent in SD
Thanks, have you been happy with the HOYA? ...and which model?
Jun 16, 2011 at 01:50 PM
