Archive 2011 · Zeiss 85 1.4 problem (seeking advise and help)
scorpioh
p.1 #1 · Zeiss 85 1.4 problem (seeking advise and help)
Hi, I am new here and was advised to seek for some opinions for a problematic Zeiss lens from Pentaxforums.
The story goes like this:
I recently acquired a Zeiss zk 85/1.4 which was plagued with some kind of "white spots" below the first couple of elements. Believing it to be an isolated case of bad luck, I got a replacement copy. Surprisingly, or maybe not, the second copy shows exactly the same problem. Interestingly, the serial numbers of these two lenses are quite distant from each other, making me believe that they are probably from very different batches - meaning this could be a common "defect" for this lens?! There also seem to be a chance of fungus since I got both of them from B&H and they are probably stored in the same place, under the same conditions.
From the lens design, there don't seem to be any gluing of the first few elements which eliminates the possibility of element separation? Additionally, the spots are populated randomly but evenly below the bottom surface of the first element and top surface of the second element.
Finally, it doesn't quite affect the IQ as far as I could tell and I could probably live with it if it is indeed some lens characteristic. Could owners of this lens kindly do a sanity check on their lenses? I thank all of you in advance.
May 14, 2011 at 10:07 PM
philber
p.1 #2 · Zeiss 85 1.4 problem (seeking advise and help)
After a thourough wipe, I can see nothing, even after angling it every which way in the sunlight. Mine is a ZE.
May 14, 2011 at 11:55 PM
Alee18
p.1 #3 · Zeiss 85 1.4 problem (seeking advise and help)
Hi Scorpioh,
I owned the ZE 35f2 and 50f1.4 and my friend the 85f1.4 and we never had such experience. Like what philber suggested, try and wipe it and see whether they can go away, otherwise get another replacement.
Anthony Lee
May 15, 2011 at 12:12 AM
scorpioh
p.1 #4 · Zeiss 85 1.4 problem (seeking advise and help)
Hi, thanks for your advice, both of you. (Hey, Anthony, nice to see you here!)
I couldn't wipe it off as it is in between the elements. It's a replacement copy and sadly, I guess I am going for the third...
May 15, 2011 at 05:49 AM
denoir
p.1 #5 · Zeiss 85 1.4 problem (seeking advise and help)
I just checked mine and no, nothing. All elements are spotless.
May 15, 2011 at 05:58 AM
ricardovaste
p.1 #6 · Zeiss 85 1.4 problem (seeking advise and help)
Make sure you complain if they're selling you something advertised incorrectly - they should refund your return shipping (if they've got any soul). Good luck.
May 15, 2011 at 06:00 AM
scorpioh
p.1 #7 · Zeiss 85 1.4 problem (seeking advise and help)
Thanks for all the sanity checks and advice. I guess both copies are going back to the dealer. I'll try my luck with another dealer.
May 15, 2011 at 07:58 AM
Lars Johnsson
p.1 #8 · Zeiss 85 1.4 problem (seeking advise and help)
It could be the beginning of "lens fungus"
Singapore is a extremely humid place.
May 15, 2011 at 10:38 AM
Jason_Thames
p.1 #9 · Zeiss 85 1.4 problem (seeking advise and help)
This looks to me like bubbles in a cemented lens. The 3rd and 4th lenses in the group are cemented in this particular lens, and it appears they are beginning to come apart. I had the same thing happen to a Canon 100 Macro, and the lens has to go to canon to be fixed. They ended up replacing the cemented lens group. At any rate, this is not normal, and I would do the same, send it back and buy elsewhere.
-Jason
May 15, 2011 at 06:02 PM
Alee18
p.1 #10 · Zeiss 85 1.4 problem (seeking advise and help)
Been here for quite a while as I was using the Canon 5D. Like to meet up with you to try some of your ZKs on Pentax and see how they differ with the FA Ltds lenses especially in rendering.
May 15, 2011 at 10:02 PM
