Archive 2011 · Nodal point for panos for ZE 50MP and 100MP
Rajan Parrikar
p.1 #1 · Nodal point for panos for ZE 50MP and 100MP
Does anyone have the numbers for the nodal point (or the No Parallax Point) for the ZE 50MP and the ZE 100MP lenses with 5DII using the ReallyRightStuff pano package (single row, landscape mode)? I plan to do the measurement one of these days and want to compare notes.
Apr 23, 2011 at 01:19 AM
Mike K
p.1 #2 · Nodal point for panos for ZE 50MP and 100MP
The choice of L bracket also is very critical in defining your setback distance for nodal point. I have an older RRS pano package and not quite as old 5DII bracket, and measuring from the center of the clamp the nodal rail for the Zeiss 50/2 MP is 117mm for both landscape and portrait orientation (some L brackets are quite different with orientation). This is a relatively short distance, as 0mm is the entire length of the rail and 180mm is near the back edge of the camera body.
In absolute measurement, I am not confident that this setback distance of my equipment can accurately compare to your set up. Unfortunately, for relative comparison I do not own the 100/2 MP, wish I did!
Mike K
Apr 23, 2011 at 01:58 AM
Rajan Parrikar
p.1 #3 · Nodal point for panos for ZE 50MP and 100MP
Thank you, Mike. I have the RRS L-bracket for 5DII. I'll note down your values for the setback.
Apr 23, 2011 at 02:02 AM
LightShow
p.1 #4 · Nodal point for panos for ZE 50MP and 100MP
I think getting the measurement from the EF mount will be of more use to anyone that is looking for this information. Just saying...
Apr 23, 2011 at 06:38 AM
carstenw
p.1 #5 · Nodal point for panos for ZE 50MP and 100MP
I have been using 110mm for the 100/2, but this is on a D3, so some adjustment may be necessary? This is the reading directly from the rail.
Apr 23, 2011 at 07:15 AM
Ardea
p.1 #6 · Nodal point for panos for ZE 50MP and 100MP
5D MkII RRS L plate RRS Pano setup ZE 100MM/2. 10.25mm setting on slide fore zero parallax.
Richard
Apr 23, 2011 at 02:40 PM
Rajan Parrikar
p.1 #7 · Nodal point for panos for ZE 50MP and 100MP
Thank you, Richard. Now I have the values for both lenses to compare to.
Apr 23, 2011 at 03:39 PM
HerbChong
p.1 #8 · Nodal point for panos for ZE 50MP and 100MP
waste of time for landscape work. not enough DOF to have anything close enough to matter.
Herb...
Apr 25, 2011 at 03:13 PM
Ardea
p.1 #9 · Nodal point for panos for ZE 50MP and 100MP
Hi Herb,
Not true. May I suggest you try focus stacking using Zerene Stacker. That solves the shrter apparent DOF with longer lenses.
Richard
Apr 25, 2011 at 03:35 PM
HerbChong
p.1 #10 · Nodal point for panos for ZE 50MP and 100MP
sorry, i know well about and do focus stacking and it is still a waste of time on landscape panoramas.
Herb...
Apr 25, 2011 at 03:47 PM
carstenw
p.1 #11 · Nodal point for panos for ZE 50MP and 100MP
I think you are assuming that everyone wants to do the kind of landscape photography you want to do. This is, however, not the case.
Apr 25, 2011 at 04:10 PM
RustyBug
p.1 #12 · Nodal point for panos for ZE 50MP and 100MP
Trying to learn about this topic ... is it such that Herb is referring to landscape without any foreground elements that would be candidates for parallax, such that by the time you reach those distances, any parallax is undetectable without a foreground reference ... like how the viewfinder in a rangefinder is 'off' for closer work, but 'fine' for longer work ??
Apr 25, 2011 at 04:30 PM
HerbChong
p.1 #13 · Nodal point for panos for ZE 50MP and 100MP
you don't use a 50mm lens for that kind of landscape photography. i stitch 21mm shots with visible objects close enough to touch from my tripod position without a nodal slide and without parallax error being visible. i also use a 50mm ZF for multirow landscape photography. anything that includes infinity doesn't have enough DOF for any object that might show parallax error to be in focus enough to tell that there is parallax error. do enough focus stacking to get to a distance where it will matter and you will have two problems, far too many images, and magnification errors since you are refocusing so that the whole thing won't stitch without massive halos.
Herb...
Apr 25, 2011 at 05:23 PM
carstenw
p.1 #14 · Nodal point for panos for ZE 50MP and 100MP
Okay, so far you have told us how we should use DoF, how we should not focus stack, and now you are telling us what to use 50mm lenses for. Why don't you just write the rest of your "rules" right now that anyone may choose to ignore them as they wish. Rigid rules rarely improve photography for anyone but beginners.
Apr 25, 2011 at 05:36 PM
HerbChong
p.1 #15 · Nodal point for panos for ZE 50MP and 100MP
doing things that are a waste of time doesn't benefit anyone except the equipment sellers. there are times when a nodal slide make a difference and there are times when it doesn't. 13 years of shooting digitally stitched panoramas told me what is needed and what isn't. for landscape work, even when you can touch the closest subject, nodal slides are wasted. indoor architectural work and macro panoramas where lens clearance of the subject is an issue are two examples where it does matter. i've owned two Kaidan full multirow panorama heads and now have the RRS ultimate after discarding a few others along the way along with a couple of dozen software packages too. do enough panorama shooting and you will know those rules called optics and can't be ignored.
Herb...
Apr 25, 2011 at 06:00 PM
Ardea
p.1 #16 · Nodal point for panos for ZE 50MP and 100MP
Well, damn I guess I have to sell all my gear. It appears Herb really fits into the catagory of "... are like opinions, everyone has one". IMHO
regards Richard
Apr 25, 2011 at 06:10 PM
RustyBug
p.1 #17 · Nodal point for panos for ZE 50MP and 100MP
Taking the 'half-full' perspective ... I think Herb is just trying to save fellow members a few of their $$$ if he can, even if it comes across as a bit 'over-zealous' at times and may not be applicable for everyone.
Been there, done that ... I'm pretty sure Herb & I are the only two on FM to ever do so.
However, as a newbie to the stitching game ... should I be reading this as "focus stacking" is an alternative method to contending with parallax, whereas nodal points are a preventive method for reducing parallax ... did I read that right ??
Apr 25, 2011 at 06:21 PM
carstenw
p.1 #18 · Nodal point for panos for ZE 50MP and 100MP
HerbChong wrote:i've owned two Kaidan full multirow panorama heads and now have the RRS ultimate after discarding a few others along the way along with a couple of dozen software packages too. do enough panorama shooting and you will know those rules called optics and can't be ignored.
I also own the RRS panorama kit and have done more than enough panoramas to know that your "rules" are wrong. If you can touch the nearest subject, you will certainly need a panorama head to do a problem-free stitch.
What you desperately "need" to do is forget everything you think you know for two reasons: 1) to become more liberated and creative and not so rule-based, and 2) stop telling everyone what they should and shouldn't do.
Rusty, focus stacking is like stitching, but instead of stitching neighbouring shots, you "stitch" (i.e. stack) shots in depth-order. You make many shots focused at different depths and use software like Helicon to create a single shot, sharp in the entire region of interest. This can be useful in situations where you cannot get enough depth of field, for example with a close foreground object of interest and a distant background, both of which must be critically sharp for a large print. It also becomes more relevant with larger (read: medium (and large) format) sensors, where less depth of field combines with larger resolution to make the whole thing more critical.
Also, it isn't actually the nodal point you want, but the entrance pupil. This is the apparent location of the aperture when viewed from the front of the lens (although there is also a more accurate optical way to find it, of course), and if you rotate the lens around this point, then you will be able to stitch perfectly (after correcting vignetting and distortion, e.g. barrel distortion) without foreground/background objects changing their relationship to each other in neighbouring shots, necessitating a lot of tedious clean-up work to make a panorama work. It is normally only necessary to use a panorama head when you start including close objects in your composition, as the relative position of distant objects barely changes when you rotate the lens/camera for neighbouring shots.
[Edit: Aham jumped in before I finished my edit: his is the short summary, same thing.]
Edited on Apr 25, 2011 at 09:48 PM · View previous versions
Apr 25, 2011 at 06:37 PM
AhamB
p.1 #19 · Nodal point for panos for ZE 50MP and 100MP
Rotating around the nodal point eliminates parallax. Focus stacking is used simply to increase DOF (usually for macro). Some info on focus stacking: http://www.macrostop.com/
Apr 25, 2011 at 06:38 PM
RustyBug
p.1 #20 · Nodal point for panos for ZE 50MP and 100MP
Thanks guys,
I'm thinking about using some 100mm glass to cover an otherwise 20mm-28mm FOV (ff) at a distances of about 15-30 feet with a DOF of about 12-15 feet (rough estimates). I'm assuming I'll incur parallax in the process, and as such need to learn how to determine nodal points and get as level as possible through the arc.
Apr 25, 2011 at 09:43 PM
