Archive 2010 · Which L Bracket for my 7D
blucenturion
p.1 #1 · p.1 #1 · Which L Bracket for my 7D
Is the consensus favorable toward the specific L brackets designed for the 7D? I've heard some are not satisfied with the new design by Kirk and RRS? I can't determine if this feeling is widespread, or not. Apparently the 50D L bracket can be used with no restriction toward the remote shutter release connection, any comments on this, please? Thanks.
Mar 02, 2010 at 01:12 AM
lowbone
p.1 #2 · p.1 #2 · Which L Bracket for my 7D
I have the Kirk and I feel it is a good design however I have not had hands on with the one made by RRS. I tried my 50D bracket on the 7D and it did not fit properly.
Mar 04, 2010 at 01:04 PM
Jack M
p.1 #3 · p.1 #3 · Which L Bracket for my 7D
I'm using the 50D RRS L bracket without grip with no issues. Fit is fine and all ports are accessible.
Mar 04, 2010 at 01:18 PM
bander
p.1 #4 · p.1 #4 · Which L Bracket for my 7D
I have the RRS bracket on my 5D2 and like it. I use both Kirk and RRS products and prefer the RRS L brackets. If you haven't done so, visit the Kirk and RRS sites and take a look.
Mar 04, 2010 at 04:44 PM
troy12n
p.1 #5 · p.1 #5 · Which L Bracket for my 7D
I have heard some people complain about the 7D RRS L bracket, I dont have a 7D, so cant tell you, but I know the 40d and 50d share the same L bracket, I have the 40d with the RRS L bracket and love it. It has a limitation where you cant use the IR remove with it because the bracket is in the way, but you can use a corded one without issue (I do).
Mar 04, 2010 at 05:29 PM
pdever
p.1 #6 · p.1 #6 · Which L Bracket for my 7D
My RRS bracket fits fine on my 7D. I haven't used it tethered and I use a wireless remote, so no issues so far
Mar 04, 2010 at 06:13 PM
RobertLynn
p.1 #7 · p.1 #7 · Which L Bracket for my 7D
wtf do these L brackets do? Is it like my stroboframe one that I keep the flash above the lens axis?
I need to find one for a grpped camera. I can use my flip bracket on my 5D, but I keep the grip on my 7D.
Mar 04, 2010 at 06:31 PM
godfather
p.1 #8 · p.1 #8 · Which L Bracket for my 7D
Robert you need to do some reading over on the general gear forum
It allows you to rotate your camera to the portrait position while keeping the weight directly above the tripod. It has nothing to do with a flash bracket...however, you need one to use some of the RRS flash brackets (wedding pro flash bracket).
Mar 04, 2010 at 06:35 PM
NCAndy
p.1 #9 · p.1 #9 · Which L Bracket for my 7D
I have the RRS L bracket on my 7D with grip. It is different than the bracket on the 5D2 in that the bottom has a 4 way dove-tail instead of the long rails usually found on other brackets. I was at first a little put off by the change because it would seem to have less surface to clamp to and might slip. But in practice it holds just fine.
What the new design allows for is to change the orientation of the camera from landscape to portrait when using the MH-01 monopod head and still make use of the tilt feature without having to adjust the clamp. That might not be important to you especially if using a larger lens with a collar or when using a ballhead on a tripod.
Mar 04, 2010 at 07:10 PM
RobertLynn
p.1 #10 · p.1 #10 · Which L Bracket for my 7D
I understand. When you take it into portrait position without one, your cam will be off-center weight of the pod.
With a camera and say smaller lens on it, probably not a big deal, but the camera and a 70-200 2.8IS, could make a world of difference.
Thanks for the education, not everyday you get to learn something for free.
I'll check into their flash brackets.
Mar 04, 2010 at 09:33 PM
pdever
p.1 #11 · p.1 #11 · Which L Bracket for my 7D
adding on to what godfather said,you also don't have to recompose when changing from portrait to landscape
Mar 04, 2010 at 09:46 PM
